The weather and free time aligned this afternoon so spent some time in the garage...
Started by tacking the rear, lower control arms together.
The bushings pulled a little but was able to flex them to get the bolt in for the rear knuckle. I had started making a spacer last month to get the lower knuckle spacing and alignment correct so I finished that and bolted that between the bushings and then tacked the other sides of the control arms which seemed to work pretty well. The control arm bolt goes in much easier now.
Then located where the front mount for the lower control arms will be and tacked those in place.
Then just had to install the control arm into the chassis!!!
I will add a cross brace to the control arms per the cad model earlier but am out of tubing at this point so will wait to tack the rear mount into the chassis for now.
Then worked a bit more on the rear upper control arms. Tried to straighten the S bent tube a little so put it in the vice and put the floor jack handle on the tube and started to gently pull. It seems that my vise is not bolted securely enough to the bench as I was about to peel the vice off the bench before stopping.
Then tried to pinch the bend a little by clamping it in the vice- again, no go. Then tried the propane torch but still no go. Will have to get the tubes bent a little more.
Tacked the outer section of the upper control arms together and ground a little bit out for the tube to attach.
Started cleaning up a bit and the shop vac has been making some noise for a while- sounds like a bearing going out so pulled that apart and oiled the one bushing and she is now nice and quiet... A good day in the garage.
