New McSorley Rorty Hybrid http://locostusa.com/forums/viewtopic.php?f=35&t=12426 |
Page 2 of 2 |
Author: | krepus [ August 1, 2012, 11:03 am ] |
Post subject: | Re: New McSorley Rorty Hybrid |
Welcome back! Looking forward to further updates! |
Author: | 53sled [ October 1, 2012, 9:57 am ] |
So after removing driver side accessories, I've tacked in motor mounts. I used 240sx uppers and jaguar XJ6 lowers (+ jag rubber) and some 2" square tubing. The sump on a 240 is in front and as of now hangs below the frame 1.25", and the lowest part of the bell housing also hangs down. So I may have to re-think the mounts, but I had kept a hold of the jag parts for a long time just for this purpose. I had to try. I have my control arms all tacked in place, but I used low grade 1/8" steel to mock up the pickup points, so I won't finalize anything until I get the Kinetic parts in. Just used clamps to hold parts in place to check lengths and angles. |
Author: | 53sled [ January 24, 2013, 3:07 pm ] |
Not much new to report, fabricating parts to turn shocks into coilovers, and got a turbo manifold for the exhaust side. stock compression on my engine is 7.5:1, begging for 5 psi. turbo KA. tasty. |
Author: | 53sled [ March 13, 2013, 8:28 pm ] |
Going to start heavy fab real soon, pedals, skin, but first I have to re-think my home made coilovers. the weld on method didn't work for me. |
Author: | BrikkaBrock [ March 15, 2013, 4:44 am ] |
Have you changed the mounts yet to adjust how much the oil pan and bell housing are hanging? Hope you didn't put an eye out with the shock setback. |
Author: | Bow [ August 28, 2013, 4:05 am ] |
53sled wrote: stock compression on my engine is 7.5:1, begging for 5 psi. turbo KA. tasty. Actually, your stock compression Ratio for a 240SX KA24DE is 9.5:1 For a Frontier, it is 9.2:1 5 psi of boost will put you about 30-40hp above the stock 155hp for the 240SX version... |
