It is currently May 15, 2021, 7:16 pm
Post new topic Reply to topic  [ 224 posts ]  Go to page 1, 2, 3, 4, 5 ... 15  Next
PostPosted: January 18, 2012, 3:57 am
After the requisite planning and contemplation phase I've acquired the big parts for my build and i'm ready to kick off my build.
I started by buying two parts cars - an '01 miata for the front and rear suspension parts & rear drive parts and an s2000 for the f20c and its 6 speed trans. After parting out the two cars I was basically able to break even with the suspension and engine parts helping to keep the cost of the project down a lot.
I'm starting with a buddies partial frame, it's BEAUTIFUL and obscenely straight. I'm going to make a few changes - he intended to put a bmw straight 6 in the bay so its setup for a different engine than i'll be using.
I've done a few build threads for various projects before notably my e36 m3 ls1 swap
Miata leaving
S2000 leaving
f20c dropout
picking up the frame
Rented a spot in an old race car builders shop to get access to fab tools and get out of my two car garage, got all setup
the frame setup on my 'table' - the friend I bought the frame from used a similar setup and highly recommended it as a good build table option becuase it can be welded on and is very flexible, I picked the whole setup up for about a 100 bucks and instead of spending hours building it I had it together in about oh 5 min.
My Build thread: F20C powered Autox & track toy
Buy my car! - F20C Race car
PostPosted: January 18, 2012, 1:18 pm
Regards, Ron
PostPosted: January 19, 2012, 1:11 am
Awesome dude. I envy your stripping of two donor cars: I only got the satisfaction of the Miata.
I'm in the neighborhood. Please let me know if I can lend a hand somewhere.
What're the dimensions of the chassis? It looks slightly different than the "book" or +442 chassis.
PostPosted: January 19, 2012, 1:38 pm
Best of luck with your build.
I checked out your bmw write up. Nice Job:)
Chris White
Locost 7 type 1 power and a rear transaxle
Lotus Elise Sold
ND Club Miata
Nissan Titan Sold
Rubi Wrangler
http://www.locostusa.com/forums/viewtopic.php?f=35&t=13200
PostPosted: January 23, 2012, 2:12 am
some very minor updates since I forgot to bring my garage camera over to the new shop area
I was able to get my "table" setup properly and modified to fit my needs
I then got the frame setup on it again and checked for level front & back & side to side - spot on almost the first time. I centered it on the table from the existing center lines on the chassis and tacked it to the table nice and center & level.
then I sat the miata diff up there to try and decide if I liked it or the s2k diff better - the s2k diff is smaller and I like it's mounting setup better but supposedly it isn't as strong...
I also pulled apart the miata front & rear subframes to get me to the interesting pieces
and despite it not looking like it I pulled a bunch of unneeded items off of the motor - the coolant hoses, the AC and some emissions stuff. I'll need to either loop or cap the heater core lines for cooling depending on how the water pump prefers. I also pulled the secondary air intake off and plugged that with a plate.
next up is fitting the motor in the engine bay to figure out what modifications will need to be done in that area
I also need to start fabbing the rear up. my intention is to mimic the miata rear pickup points. I received some suspension brackets from Mr Jack @ Kinetic so I"ll have those to use. I have a few more fiddles within my suspension analysis program to make and then i'll post those up for a review here.
PostPosted: January 23, 2012, 2:16 am
I don't know if envy is the right word, that s2k was a PITA to take apart, so much more complicated than the very easy miata.
chassis dimensions are at the front 26 3/4 across the top and 21 1/4 across the bottom - 15" tall - along the back of the frame 46" and somewhere shy of 8' front to back right now.
front suspension rear tubes are 9 3/16" behind the front of the chassis.
You're welcome to swing by and take a look as I get some more progress in - i'd love to discuss pain points
Thank you sir!
PostPosted: January 23, 2012, 3:37 am
This car will have so much less weight on the tires that the diff strength is likely much less of an issue. If you have half the weight on the tires, you'll only be able to put half the torque thru the diff...
PostPosted: January 23, 2012, 11:59 am
Not as strong how? From what I recall, in the Miata world it's generally accepted that the S2k differential is based on the 1.8L Miata differential, but actually offers a stronger drivetrain due to a shot peened ring and pinion and its use of larger stub and half shafts. I know there were some issuse with the case strength in the AP1 cars, but remember too that the S2000 is both heavier than a Miata and has forced induction Miata power. Off hand I don't know of any direct comparisons to validate whether the early case is physically any weaker than the Miata ones. And speaking of weight, don't forget how much less (~50%?) of it the differential will have to fight in this car. Especially considering the stated purpose of this car, I personally would probably be looking moreso at which setup is lighter...And wouldn't forget to post the weights for the others on this site who have inquiring minds.
PostPosted: January 23, 2012, 9:47 pm
Nice another F20C locost.
I'll be watching this thread with interest.
Lotus Elise
F20C Locost
PostPosted: January 24, 2012, 3:05 am
Hi Tongboy, good to see another Portlander building a seven. I finished mine when this forum was just getting started so I never developed a build blog of my car. But circumstances have changed and soon I will start one to document the changes I am making to satisfy a local racing organization that questions the safety integrity of these cars for track days. Which brings me to why I'm here. When I saw your title stating you plan on a track toy be advised that rollbar requirements vary widely depending on who you participate with. Since you are at the beginning stages I would start thinking about the rollbar now and incorporate it into the chassis before it becomes nothing more than an after thought like they more or less are now with the original design.
It seems most race sanctioning bodies want the main hoop to start on the lower frame rail then up to the required height and across the cockpit to the opposite side lower frame rail then tie in your upper frame pieces to that hoop. If I were to build another car that is how I'd start. If you look around on this site there are some good examples of this type of construction.
I have a friend with an Ultralite that has the S2000 engine and trans. I think it's a good choice for these cars. We should have meet up with all the builders and owners in the Portland area like they're doing in other areas. Good luck with the build and if I can help with any questions feel free to contact me.
Jim Larfield
PostPosted: January 24, 2012, 11:11 am
Jim, do you think your local folks also require a tall front hoop?
I think it makes sense to design a roll cage that matches the passenger compartment of a Seven or Locost and then build the car outwards from there. It minimizes any weight or space penalties and just seems to make sense, the tubing is there just use it...
PostPosted: January 24, 2012, 12:04 pm
Here's the club brother Phillip is in. .... He tells me that they have a couple of Locost7s. (hmmmm plural of Locost7. .. :? )
http://www.eescc.org/
PostPosted: January 24, 2012, 11:51 pm
Good info all around guys - I'll get back to it when I have a moment but I did want to provide the s2k diff weight as someone asked about it
69lbs 5.4 oz on my new & very accurate postal scale - this is drained but still with the axle cups & rear mount piece (that rear mount doesn't weigh much...) I'll check it again after I pull the axle cups.
PostPosted: January 25, 2012, 2:01 am
I'd agree that the weight is massively reduced on the smaller car but I would also say that by stepping up the size and adhesion limits of the tires that it isn't directly half the torque pushed through the driveline. a hard prosolo drag launch on R comps even in a 1400lb car is going to put more stress on a diff than hard street driving on 350 wear tires on a stock car.
From what i've been able to find the s2000 diffs aren't terrible for stock power levels but they tend to break whatever the bearing holders are that hold the diff into the casing (like lower rod arms breaking, i just don't know the proper name) they sell a few kits to strengthen it but the miatas don't have that as a failure point - they'll toss axles and shred gears, I suppose it's six and a half dozen either way. I do agree they certainly hold more power factory spec to factory spec by far. both setups deal with roughly the same torque output from the factory FWIW.
Total weight of the diffs isn't something I thought of - that's a good point. I'll have to throw them both on the scale for equal comparison. I also want to find out if the driveshafts are compatible - the s2000s are wider than i'd like to use but I could work with them - i'd then have to check if the outboard CVs are compatible to the miata spindles as well...
Jim Larfield
Hi Jim! Thanks for the great information. I'd love to chat rollbar design with you as I really am at an ideal phase in the project. My intention was to run a 5 point rollbar and try and get as much rear arm angle as I can. And then run a seperate full cage that bolts up toward the windshield for wheel to wheel racing. You've got me thinking about maybe a more permanent main hoop and a front hoop integrated into the cowl area with the appropriate ties. I'm trying to meet the SCCA road race regs which will get me the scca solo2 rolled in and be meaningful when chatting with the NASA guys if I head down south for any of their events. I'm told conference runs somewhere near the scca specs but I haven't been able to talk extensively with anyone there yet. Any experience you'd be willing to lend would be much appreciated.
I've run an autox with those guys, very friendly and welcoming folks. I'd like to run their next hillclimb if I can get out of design paralysis and get moving forward.
I know a friend of a friend with a crazy powerful LS-powered locost car that runs with them on a semi-frequent basis.
PostPosted: January 25, 2012, 3:26 am
Marcus, no they don't require a tall front hoop, but what they seemed to be concerned with is the rollbar collapsing straight done in the event of a rollover. They question whether there is enough structure underneath supporting the rollbar at it's high mounting point. The problem is that most of the people in this racing organization don't understand tube frame/space frame construction and how it gets it's strength. The majority of them race street based production cars. Purpose built race cars have taken a huge decline with this organization in recent years. When I pointed out to them that older formula fords (that still race under ther sanction) had there rollbar welded to the upper frame rail, they were quick to use the homo word as in homologation. My car was not homologated therefore they could not take a chance in the event of a crash. The current board of this organization likes to deflect any responsibility/liability to any other racing organization that they can. For example if your cage had an SCCA stamp on it then it automatically qualifies with them even though there minimum tube diameter is 1.5" and .120 wall. That's if you're building a car to only race in conference. I believe SCCA is 1.375" and .085 wall for the lightest weight car.
I could go on with my frustrations with this group (International Conference of Sports Car Clubs, ICSCC, of simply known locally as Conference) for a long time but this isn't the time or place. I'm not trying to race with them just participate in the HPDE events they usually have the Friday before they're race weekend.
Tongboy, PM me with contact info and I'll tell you what I have learned about the rollbar/ rollcage issue and hopefully send you in the right direction if I don't have the answers.
Jim
