Time for another giant update.
Been busy working on the nose and getting the car sorted out for the next event which was yesterday
I made my first carbon piece to test out the material and the process. I molded a pedal cover to go over the master cylinders to be thee last part of the firewall
My tires showed up
the front nose came along nicely. I used latex as a cover coat to work on levelling and getting everything properly in line.
it would then get sanding and lots of bondo to continue the finishing
rinse and repeat sanding and dust for forever
the final layer was a two part sealer. it did a great job at filling a few low spots and gave it a nice shiney candy coating
then came the floor wax and PVA
then the gel coat
and then came the fiberglass
and the second piece
and the third and final piece
I haven't snapped any shots of the mold off the bucks but it came out pretty well. I'm at that point now where I need to fill in some spots on the mold pieces before I lay the final part into it
my wheels showed up and I got the tires mounted
11.45lbs a piece - not bad for a very affordable 13x10
finished up the rear deck spoiler. still need to flip the L bar on the top and make some side pieces
I was making up parts to lengthen the steering rack to delete the bump steer... while doing so I played with really large height changes on the tie rods to the rack and was able to go from a huge amount of bump steer (insane toe out, like 1/2" total toe out at full bump) to 4 thousandths on one side and 5 thousandths on the other side. a small enough amount of deflection that I couldn't see it in the wheel and could only see it via measurements. More than good enough for now.
Pulled the car back down and scaled it - with the changes over the winter and the smaller fuel tank I installed it's down about 25lbs less than I expected it to be... 1174 wet. which will work out to be just about ideal with the finished up front end. I attribute the extra weight loss to pulling to seats and running foam in their place. With my chunky butt in it I'm over minimum weight.
My co driver working on ride height before we corner balanced it
All ready to go out
Co-driver about to go scrub down those fresh Avons
the alignment really helped. When I strung the car and scaled it it was really out of whack - the corner weights were all off and as an example of how bad an eyeball alignment is - the rear total toe was about 1/2" out
with all the changes the car went from really hard to drive & pushy to feeling absolutely fantastic. I went from 4.5 seconds off of the FTD pace last time to a solid 1/2 FTD finish with a good margin and the best PAX finish I've had yet.
Even on the really patchy and chewed up lot we ran at the 2" front and ~3" rear ride height and didn't have any problems.
2 more weeks to the next event that is a two day at packwood. Really excited about running the big course and by then I'll hopefully be done with the front nose & splitter.
I do have a question for folks - with the light gauge aluminum rear fenders I'm amazed at the rock hits showing through after one event. What are people doing to minimize punch through on fenders?
