It is currently January 22, 2018, 10:23 pm
Post new topic Reply to topic  [ 378 posts ]  Go to page Previous  1 ... 22, 23, 24, 25, 26
PostPosted: September 6, 2017, 4:38 pm
Beautiful work John.
K0RKK 146.460
spearfishcreek.net
Royce
PostPosted: September 6, 2017, 4:45 pm
JSArmstrong wrote:
A truly awesome build!! Thank you for the updates John, what thickness Ali did you use to do the sump modifications?
Thanks!
I used 3/16" thick 6061-T6. The stock pan measured about 0.120-0.140" in most spots, so I added a little bit for safety. You lose the T6 heat treat during weld, but the aluminum is still very strong and malleable (rather than brittle) so I think it's pretty safe. I also used 4043 rod - recommended for welding to cast aluminum. I did a quick "cleaning" pass and then wire brush before performing the actual weld with filler rod. Seemed to work really well and I had no issues welding to the previously oil-soaked pan.
- John
PostPosted: September 7, 2017, 9:19 pm
I know you're not truly "finished", John, but did you put yours in the "Finished Builds" thread? It's a great example, and I think it definitely should be there as a terrific inspiration for potential builders. On-going improvements could still go here, I'd think.
