geek49203 wrote:
As I recall, 2", making this a 28" arm. And 28" can be purchased fairly cheap from places like Speedway -- I mean, why make your own stuff when it's cheaper to buy? Ditto for axle brackets too.
You're laughing then Mate, 28" it is then - good info for the other thread too.
geek49203 wrote:
Once I get this all in place, and once it's all with lots of adjustment holes on the front end of each rod, how would I know how to adjust it? What am I looking for? Given the torque / weight on this build, I assume I'll always be looking for more forward bite?
Thanks!
Primarily you're looking for the torque not to upset the chassis balance under hard acceleration and for the car to go in the direction the steering wheel is pointed. Also go around some left and right corners and compare how much the RHS wheel picks up and spins compared to the LHS wheel while accelerating hard out of the corner.
Watch Rod's V8 accelerate at 3.14 and 6.19, note the left rear wheel is driving harder than the right and sending the car sideways, this is what you want to adjust out .. (that's no slight on Rod's great build by the way.)
http://www.youtube.com/watch?v=jqvYJlYc4GUOf course your starting point should always be everything equal for your baseline and making changes/testing from there.
