The engine is back in and working after a slight mistake getting the timing gear a tooth off.
Seeing as the engine was out I made loads of changes, heres the short list.
1. Rebuilt and destroked engine from 2.2L to 2.0L
2. Changed transmission to custom 4 speed AP1 transmission
3. New lighter clutch and lightened pressure plate
4. Short shift gear stick (home made)
5. Moved steering rack forward 6" and shortened steering arms
6. Moved radiator back 18" and rerouted coolant hoses
7. Remade driveshaft cover.
8. Removed about 20lbs of stuff I doubt I needed
9. Raised the front of the car and corner balanced
10. Removed 2nd seat and ballast car is now 120lbs lighter.
The car with me is now weighting in a little under 1640lbs which I am really happy with. I was hoping for 1650lbs so stoked with the result. It was a hole lot of removing less than 1lb here and there.
New drive shaft cover which is about 3lbs lighter and looks less [PooPoo] then the old one
Radiator moved back I was tempted to move it to the rear of the car for weight distribution but it seemed like a lot of hard work, steering rack moved forward and steering arms shortened accordingly. I also removed about 10lbs of "stuff" from the front
Here is a pile of lightness.
Scrap Metal Build Log
viewtopic.php?f=35&t=14558
