horchoha wrote:
It pleases me to see how the group pulls together to find a solution to a problem.
I followed Chuck’s lead and went down the Google rabbit hole on the CV joint grease question. Learned more than I wanted to know about tripod-style CV joints and their lubrication requirement.
For the inboard, tripod style joints, Pegasus Racing summed it all up pretty well, paraphrasing the info on the GKN website:
“The needle bearings in tripod joints can overheat easily because the rollers slide along the length of the needles in addition to spinning around them. The very tight tolerances in tripod joints also do not tolerate solid additives, which can jam and cause the bearings to seize. This special grease from GKN has high scuffing resistance, but without the solid additives typically found in CV grease….This grease is designed specifically for use in tripod joints. Use of the wrong grease can lead to premature failure.”
Maybe that explains JD’s Giblets. While GKN’s tripod grease is pricey, saving an axle may be worth it, not to mention the time removing the giblets.
For the outboard CV joint, typically a Lobro-style , a different type grease is needed to handle the heavy spot loading. Motorsport grade CV joint grease is available for the outboards at pretty good prices if one shops around.
Guess I’ll be doing some shopping, for
two kinds of grease.
