eh3civic wrote:
So far I've changed from a 2 row aluminum radiator to a 4 row aluminum radiator. That roughly doubled the travel distance, but it still overheated, just a bit more slowly as expected.
The trouble with adding radiator rows is that each additional row gets heated air from the row ahead of it. Think of it as having two 2-row radiators and feeding the hot air from the first into the second, so doubling the cores doesn't double the cooling, as you've found.
eh3civic wrote:
...still overheating after about 10 miles of normal driving from 35-55mph and a few stop signs...)
Forcing all the air through the fan is a double-edged sword. On the freeway the fan is off yet all the cooling air is being forced around the blades of an unpowered fan instead of being allowed to flow freely. As an experiment, try removing the ducting around the fan and see if that improves cooling at speed. Granted, it'll hurt cooling when stopped, but you're going to have to try things to see what's what.
eh3civic wrote:
...I am currently having to fill the coolant system via an intake port (highest point in the system) and feel like I probably can't actually bleed out air which could be my entire problem...)
Think through how the water flows and add bleed lines and a coolant header tank to self-purge air from the system. Every high point needs a bleed line back to the header tank, and the bottom of the header tank has a small hose running to the pump inlet. I use this setup on my car and it's well worth the effort.
The real solution to cooling is feeding cool air from a high pressure region and not letting it sneak around the radiator, then routing the exiting air into a low pressure area which will suck the air out. A properly ducted radiator can have a shockingly small inlet. Look at some of the early 300-400 hp formula cars.
Midlana book: Build this mid-engine Locost!,
http://midlana.com/stuff/book/Kimini book: Designing mid-engine cars using FWD drivetrains
Both available from
https://www.lulu.com/
