Lonnie-S wrote:
I think you have a pretty good plan. As you're doing a one-off, I think some level of mocking up is warranted. I did it with mine, and it allowed me to solve some problems before cutting steel and welding. You may not need something as detailed as mine (below), but making sure you have enough room to sit comfortable, and have enough room for the pedal box (and your feet) is crucial.
Laying out the rear suspension (I used a live axle with the Haynes Roadster architecture) was the thing to do. Also, I layed out the transmission tunnel using blue painters tape. I put the engine and transmission in place in the mock-up. It took me 3-4 tries laying it out to get a good all-around layout. Still a roll of painter's tape is a lot cheaper (and easier) than trial and error using steel.
By the way, having your kids help out is really great. They're going to feel a real sense of pride in what you have all done together. You'll create a lot of great memories for them.
Nice mock up.. My plan is to build a integrated roll cage into the frame using 1.75 tube. If im reading the requirements correctly I'm grossly oversized for the tubing pr. weight of the car ..However Id rather have it over built to contend with any sort of "incidences" of the larger suv type on the street.
Ill probably be doing about the same setup but using 1.25 ID pvc pipe "has a 1.75 ish OD " I'm going to use the original F27 frame layout as a guide for this one. I figure Id build the car to fit me and any lesser human beings that would dare to take a ride in it , Im 6'1" 210 and broad in the shoulders..or greater human beings if they think they can fit ..
I did a seat mockup to see what it would be like in different width seats I found a 16" saet to be the most comfortable.
as for seat bottom to seat back angle and (layback?) I went with 55* I measured a vehicle that I enjoy driving very much and that is the most comfortable in for long duration trips and used this as my pattern for measurements.. It happens to be an 06 f350 ...The seat has a bit of a tilt to it but I find that its very comfortable and naturally fitting for my leg length and foot movement on the pedals. My hope is it will continue the same feel even with the different dynamics of driving happening. I notice that I tend to sit my head up farther and get closer to the steering wheel and pedals for better control of them when I actually driving vs. adjusting them in a stationary vehicle..
The seats I'm planning on a custom seat.. one more artistically modeled than the one for fitting me. I don't want just an aluminum seat or to spend the money on a carbon fiber seat that did not reflect the vehicle design and character.. I'm thinking of making some good looking baltic birch laminated wood seats with seat covers or full covers. Imagine a good looking curved wood backing resembling a high end plywood that would be the seat structure and then a snap in (leather? ) insert with padding build in to it. I want them to be a low back design to stay right around the top edge of the body work and then have separate headrests mounted on the roll bar...
by using a very thin wood veneer I believe I can bend and form the seat back in multiple layer and possibly put carbon fiber or glass cloth in between or outside the layers for a skin and use the wood as a type of honeycomb core in a composite. I remember a composite book I had read stated that in ww2 ? they used this type of technique on an airplane fuselage using just the wood with the wood grain oriented in different directions for strength. and laid it all up in a mould as you would fiberglass.. I found some inspiration in a set of porsche seats..
Next I was deliberating on different pedal arrangements, hanging vs. floor mount vs. stange combos of both for a beater toe heel.. in the end I believe the floor pedals make the most sense for the way the car is set up and gives me a decent amount of travel and foot room .. pedal travel will probably be a subject for a latter date as will brake system design and trying to stay with in the ford parts bin, it may be an interesting experience, but I already have a few plans..
As for the ECU I had originally thought of going with a fairly plug n play approach while being semi budget friendly..
https://www.aemelectronics.com/products/programmable-engine-management-systems/universal-programmable-ems-4/universal-programmable-ems-4It seemed to do everything I wanted without all the soldering, I don't mind soldering and tracing wires but electronic components is where I tend to call it..
I had wanted to keep the OEM setup but didn't care for messing with PATS or having another gauge cluster from a fusion buried inside may dash somewhere..
But with this newer OEM hackable ECM set up I may take a second look at it..I still have all my factory connectors on the engine and factory harness plug in tacked ..
GonzoRacer wrote:
I think the little guy is going for "Bang shift to second, bark rubber and haul a$$"... He probably doesn't know those words yet, but the concept is there. You can see it in his expression. That gives me renewed hope for the next generation. I LIKE THAT KID!!! Send him on down, I'll let him drive the Slotus.
"Uncle Bubba"
YA no doubt .. Im sure if we're ever down your way he'd take you up on your offer..lol... personally as a parent I don't necessary push my kids into any one thing but instead use there curiosity and what they find interesting to draw them in to that and let them be a part of what I already enjoy .. I do expose them to a very wide variety of motor sports just to peak their interest as to what's out there and what's possible everything from australian stadium trucks doing jumps with uber soft suspension, f1 offroad, dirt drags, formula D, salt flat racers, super cars, hill climbs dirt and road, WRC
swamp buggies, dinghy racing, exc.exc..and a variety of car shows during the year..
Driven5 wrote:
If you still end up really set on the T5, there is always this option:
https://www.holley.com/products/drivetrain/bellhousings/bellhousings/parts/RM-8090However, once you've gone through the trouble of packaging the M5OD and building a remote shifter, I don't think there will be enough reason to change it out for a T5. On paper, the ratios really do look reasonable to me, and I think that the 3.73 could actually be pretty good with your larger wheel/tire package too. Along with that, I don't know if you ever saw the outcome of my flywheel escapade, but Spec now sells this beauty:
https://www.locostusa.com/forums/viewtopic.php?f=4&t=18943Thx I did see the holly product, I was a bit confused as it said for ecoboost .. but I couldn't justify the price tag for what i'm doing.. I did see your end result.. I must applaud you on your perseverance.. I'm still thinking there's an easier way with mostly OEM goodies and just one or two custom parts to make it work.. My thinking is if the bell housing is custom the flywheel could be readily sourced from the focus, miata ,exc. they have a lot of availability and options with huge aftermarket support and will more than likely be available for a very long time. then do the same for the clutch. I would think the T5 platform will out live the M5OD-R1 for the years to come but for now I believe your right in the fact the M5OD-R1 should work great in my current set up..I plan to keep poking at this T5 business but nothing to serious yet or at least as long as my M5OD-R1 stays alive..
