Its been a long summer with little activity on the seven. Way to many other projects and honey do's. Also my 2 1/2 year old daughter is a night owl so I have spending time with her at night rather than in the shop. I ain't complaining though, she is a blast and much more important than the seven.
This past week I was alone at the house without any other projects so I made time for the seven. I finished tacking together the lower control arms, so all the control arms are done except for final welding them. I put the frame back on the build table and tackled the pedal box. I am using wilwood floor mount pedals and miata hanging gas pedal. The pedal box is removable by two bolts at the top and all the bottom bolts of the pedal brackets secure it to brackets welded to the frame. It is very secure. I am not sure if I need to do any gusseting to it or not. It seems solid as it is. The gas pedal took some pondering, but I think I have a good solution. I did slot the bracket so I can adjust the height of the pedal in relation to the brake pedal for heel toe shifting. Once I get the car on the road and test it I can lock it in place. Next task is getting the steering wheel mount done.
