It is currently February 28, 2020, 11:26 am
Post new topic Reply to topic  [ 558 posts ]  Go to page Previous  1 ... 30, 31, 32, 33, 34, 35, 36 ... 38  Next
PostPosted: August 21, 2019, 11:14 pm
In the frenzy to get ready for the inspection, I ordered and installed a VDO GPS speed sending unit. It could not be easier. The tachometer on the other hand was the polar opposite. I struggled for a year, yes, a YEAR trying to get that F*&^ing thing working and no dice. Upon multiple emails to VDO technical support, I learned that it needs more than the 5 volts that they told me originally. My ECU for the BMW M42 motor puts out from 4-6 volts depending on the revs. They suggested a pull-up-resistor but didnt offer what size :BH: . So, through trial and error, and YouTube videos for LS swaps, I determined that a 1k resistor did the trick and I now have a tach :)
Gavin
PostPosted: August 22, 2019, 8:53 am
Mnot
Sorry for the late come back, usually only go through posting once a day in the mornings.
Did not realize you were using an electronic flasher. My suggestion will not work with one.
Chuck provided you with a better way to deal with your problem.
Red
PostPosted: August 23, 2019, 10:16 pm
I PASSED!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I mailed the paperwork and the $15 check today. Hopefully I will have a title for a 1960 Lotus (Replica) in a few short weeks :D
Gavin
PostPosted: August 23, 2019, 10:33 pm
After the Autocross I determined that the ride height was way too high and springs were too stiff. Somehow, with all of the changes with the suspension and mounting, the car gained ride height. My ideal, was to be able to clear a 4x4 piece of lumber because it actually happened to me in my GTI and I cringed going over it (i cleared it). So, that was my benchmark. For my sump to clear a 4x4, my frame would need to be 5.75". In order to accomplish this, I had to cut the upper shock mount and reduce the length, thereby increasing the shock angle. I gained several things from this change:
1. increased clearance of UCA - see question below
2. decrease effective spring rate (463 lbs/in stock spring from Suzuki SV1000)
3. eliminate the brace bar for the shock mount. Because it was so long originally, I ran a 3/4 x 0.120 tube from the top of the bottom tube of the frame up to the bottom of the upper shock mount.
4. reduced weight because of #3
Now that I have all of this space for the UCA, I am contemplating building new ones that are easier to adjust. Jack's design seems like it might work for me but I would have to install it in reverse orientation that he shows. I would also need to bend the forward tube which would have a heim and a clevis. I did my best to illustrate this forward tube shown in teal. the dotted line is the clevis mount (5/16" plate with a 5/16" bolt). My question is, is my orientation okay given the loads from braking? Or, will it try to tear itself apart?? The tube shown is 1.25" x 0.120 wall and the curved tube located in the front would be 1" x 0.120" wall.
Jack's design:
Gavin
PostPosted: August 24, 2019, 12:08 pm
Congrats on passing the inspection, Gavin. That's huge!
PostPosted: August 24, 2019, 9:12 pm
Thanks Lonnie. Soon we will have another Locost on the road!! Just in time for the fall weather when it is best to appreciate the open top design of the 7. Of course, it is far from done and i still have to dismantle the car to finish weld and paint the chassis but i will likely drive it around little bit just because I can (once i get tags).
Gavin
PostPosted: August 25, 2019, 7:54 am
Uhhh... You need to look up some Locost history related to one Dave Hempy. Dave is one of the original members of the forum and still does the work behind the scenes to keep it up and running. He took his Locost for a test drive before he finished welding the chassis with some disastrous results. :cry:
He also slipped out to the garage in his skivvies and took pictures of the headlight buckets and posted them. With his reflection in the shiny new chrome headlight showing all the world his (lack of) attire. But that's another story... :mrgreen:
Maybe you meant drive AFTER disassembly and final weld, in which case, sorry for the sermon.
If you meant it the way I read it, beee carefullll!!!
Peace, Love and "Can't wait to drive it!" --
PostPosted: August 25, 2019, 11:59 am
A bit over dressed in my humble opinion, don't think JD? :rofl:
PostPosted: August 25, 2019, 9:01 pm
Thank you for your concern JD! I meant it how you read it but the truth is that it is 90% welded. All the suspension and main components of the chassis are welded. What is not welded are the tubes I added beyond the typical chassis tubes. For example, the triangulation of the rear roll bar brace, Of course there are a few places that I have noticed that got missed and want to be sure that I double check the entire chassis before moving onto paint and body. I may also redo a few early welds just for confidence :cheers:
-gavin
Gavin
PostPosted: August 28, 2019, 9:17 pm
As I mentioned earlier, at the autocross I noticed that the car was just too high. So, I shortened the upper mounts front and rear. This changed the angle of the front for the better because the spring rate is better (it was too stiff) and I gained a ton of clearance between the UCA and the shock. I shortened the rear mount by 30mm. Now, my chassis rails are 145mm in front and 155mm in the rear with my sump 90mm. Here is the V-susp and Wishbone figures:
Final Suspension Figures
Gavin
PostPosted: September 25, 2019, 6:34 pm
I got my title in the mail today :D
I now own a "1960 Lotu Super" according to the great state of SC :cheers:
Gavin
PostPosted: September 25, 2019, 7:02 pm
That's a great accomplishment! Congratulations
PostPosted: September 25, 2019, 7:23 pm
Gavin.
I share your exuberance. I felt that way when the HP person asked where I wanted my VIN tag riveted on.
A big congratulations! Well done sir!
Cheers
Larry in Seattle
PostPosted: September 25, 2019, 9:50 pm
Thanks guys, I am thrilled! Tomorrow I plan to pay the taxes and get plates for it. It really isn't "presentable" for street use but it will be fun to take the kids around the neighborhood :)
Gavin
PostPosted: September 26, 2019, 7:35 am
Way to go, Gavin!!! I hope you and your "Lotu" will have a great time on the road. :mrgreen:
JD
