It is currently August 12, 2020, 8:42 pm
Post new topic Reply to topic  [ 478 posts ]  Go to page Previous  1 ... 14, 15, 16, 17, 18, 19, 20 ... 32  Next
PostPosted: October 29, 2016, 8:54 am
Yup, we could all use a bigger shop, Perry. You're making some money with yours, at least.
It looks like you may get some more use out of that convertible top this winter, Perry. We're getting stories about the polar vortex shifting off to the east this winter, with warming of the high level atmosphere over our North West, your B.C. and Yukon, plus Alaska as I'm reading the graphic (link) below.
Shifting polar vortex? ==> http://www.msn.com/en-us/video/newsworl ... vp-AAjw1NB
PostPosted: October 29, 2016, 1:12 pm
Wow - quite a job to fix that heater core! Looks like they hung a heater in the air & built a truck around it... :roll:
PostPosted: December 4, 2016, 12:32 am
Well hello everyone!!
After taking the summer/fall off from building I put the RC airplane stock in storage and moved some shop items including the valve grinding machine, engine hoist, engine stands, and build table to the hobby shop side of the shop. This gives me room to put the 7 to the side when I need to work on customer vehicles.
I have the 7 of car dollies so that I can move it around easily.
Started plumbing in the fuel lines. I decided to use the gas vapor recovery system on this build so I need to order more fuel line as an after thought. I will do that once we get back from Barbados in middle January.
7 pushed to the side when not being worked on.
PostPosted: December 4, 2016, 2:58 pm
Hey Perry,
I'm glad to see you're back at it. Have big time fun in Barbados.
I took some time off myself to totally upgrade our home (including my office space), which was way, way overdue for it. Just yesterday, I moved all the household things out of my garage/shop space and back into their places in the revamped house. So, now I can start work again on my own build, beginning this week.
PostPosted: January 1, 2017, 12:03 pm
Happy New Year to All!
So.......I have another year to get things done that I didn't do last year, can't complain :cheers:
Goal for 2017 is to finish this 7 :lol: , because I've purchased the drive train for #4, The Super Slant 6 Se7en
Anyhoo, hope to see a lot of buildin' and bs'n going forward into 2017 with this awesome group of people.
PostPosted: January 2, 2017, 11:16 pm
Yo, Perry! Not sure about the buildin' but I think I can help you out on that other category... :mrgreen:
Guess you and Mrs Horchoha made if back from the islands. Good to be home safe, huh?
Happy 2017 to you, too!
PostPosted: January 2, 2017, 11:34 pm
Hey Perry! Love the name of the upcoming slanted six seven. As an old Mopar fan, I can't wait to see this one.
PostPosted: January 31, 2017, 11:54 am
Well, I went out to the shop yesterday and introduced myself to the 7 and shortly thereafter commited fabrication.
I welded up and installed a mounting base for the EVAP canister. Mounted the EVAP purge solinoid and vent valve, then plumbed it all in. Finished up all fuel line from the tank to the front of the car (with the exception of mounting the lines to the tunnel).
File comment: EVAP system
I then measured, cut, and bent straps for tying down the tank. Welded 1/4" bolts to the ends of the straps.
File comment: Bolt welded to strap end
File comment: Mounting straps
Using 1/4" thick rubber strips on the base and 1/8" rubber strips on the top corners, the straps are installed for test fit.
File comment: Rubber strip
File comment: Fuel tank mounted
Next project will be the filler neck mount.
Feels good to be at it........................
PostPosted: February 1, 2017, 12:29 pm
Yesterday's project was mounting the filler neck. Did some figurin', scratchin', and cuttin'. Then tacked it all up.
The plan is to have a recessed filler and have the marker plate hinged to conceal (just like #2 LSO seven build).
File comment: Filler mount pic1
File comment: Filler mount pic2
File comment: Filler mount pic3
File comment: #2 LSO 7 marker plate base covering gas filler
On a side note, here's a tool that I can't live without when fabricating. IMHO everyone should have this. It's cheap to buy and it doesn't cost very much either.
File comment: Seamstress tape measure
PostPosted: February 1, 2017, 1:04 pm
See, I told ya! You're past me already.
Glad to see you back at it.
PostPosted: February 1, 2017, 2:06 pm
That is a slick filler neck
Steve
PostPosted: February 1, 2017, 9:57 pm
Thanks Steve, I like to keep things simple and try to use as much as the OEM peices as I can even if it means reworking them to fit the purpose.
Hey Lonnie - Nah, this is no race, just fun building cars :cheers:
So out to the shop for a bit today. Decided after a good scratch that I was going to fab up the front nose frame out of 16 ga steel.
Set up the plasma cutter and plywood pattern and fabbed away.
File comment: Setting up to cut pattern
For those of you that are on the fence about investing in a plasma cutting for car fabrication, I took a short vid today cutting some 1" strips to build the nose frame. You really have to bend your ear to hear me, wasn't talking too loud.
https://youtu.be/3il1i9ZMBFg
Cut and welded everything up and test fit with cleco's.
File comment: Cleco's for everyone! 1
File comment: Cleco's for everyone! 2
Attached to the frame using riv nuts and 10-24 aviation screws. Used rubber washers between attach points and nose on the front attach points.
File comment: Inside view of side mount with 1/8" thick rubber washer between
File comment: Side mount attachment point
File comment: Rear attachment points
PostPosted: February 1, 2017, 11:24 pm
Yo, Perry!
Mighty fine lookin' sheet metal work there, Bro! Mighty fine...
How deep is the snow???
JD "Let's go to Barbados" Kemp
PostPosted: February 2, 2017, 10:12 am
Hey thanks JD
Nice to see that you're enjoying the Slotus after all your hard efforts.
Believe it or not there's not as much snow as there should be here. If it stays this way, we will need spring rains or it will be a very dry spring - that gets the farmers a bit cranky.
PostPosted: February 3, 2017, 2:12 am
Well
Went out to the shop after supper, (it was a lazy retirement day today), stood around and scratched a bit. Now I'm doing things in a diffent sequence on this build to keep things interesting. Normally before I build the scuttle I would have the floor and tunnel 16 ga steel in place, lets try something different.
Fabbed up the frame for the pedal assembly out of 3/4" 16 ga sq tube. I will be making a removeable cover to access the pedal assembly.
Then I had to sit down and have a talk with myself.
I said self, how many times do you have to burn your thumbs before you throw these welding gloves away that are just broke in but have holes in the thumbs?
So I regretffuly gave them up for some new ones.....
Users browsing this forum: No registered users and 38 guests
