It is currently August 14, 2020, 9:52 am
Post new topic Reply to topic  [ 478 posts ]  Go to page Previous  1 ... 15, 16, 17, 18, 19, 20, 21 ... 32  Next
PostPosted: February 3, 2017, 5:35 am
And like most of us, you probably put the old pair on the shelf, just in case, because they really aren't that bad.....
PostPosted: February 3, 2017, 10:05 am
I remember a Peter Egan column where he talked about saving old brake pads that were only good enough for races where you planned to blow the motor on the parade lap... And I said "Guilty, Your Honor!" :ack:
PostPosted: February 3, 2017, 1:11 pm
Yeah, yeah, I'm guilty of having OGS (Old Glove Syndrome) myself. :lol:
The way I finally solve the problem of getting them out of the shop area is when they get demoted down to either: 1) the gloves I put in my Explorer to use at the metal suppliers & salvage yards; or 2) the pair that I use for holding the end of the stock on the horizontal band saw. In the latter case, they eventually get saturated with cutting oil and become useless.
I suppose I could get one last use out of those gloves by using them to start the charcoal briquettes in the barbecue? But, the neighbors would be sure to complain about the smell of that sulfur-based oil burning in the back yard. Maybe I should just continue to throw them out? :mrgreen:
PostPosted: February 3, 2017, 3:08 pm
[quote="horchoha"].....
I said self, how many times do you have to burn your thumbs before you throw these welding gloves away that are just broke in but have holes in the thumbs?
Nothing a little duct tape can't fix :mrgreen:
Guilty here too. Maybe I'll put new gloves on my Xmas list. :cheers:
PostPosted: February 3, 2017, 5:14 pm
Yeah sometimes when my wife uses the excuse of something being old as a reason to replace it, I ask her if that applies to relationships as well. Sometimes she gets my point, other times she gets irritated.
PostPosted: February 7, 2017, 8:48 pm
Out to the shop this afternnon.
Cut out sheet and stitched in the top deck. Cut out a hole for clutch/brake pedal cross shaft removal. Couple of pics.
File comment: Hole cut out for cross shaft removal.
File comment: Pedal box top view.
Fabbed a removable lid for the pedal box. Couple of pics.
File comment: Lid for pedal box and cross shaft hole capped.
File comment: PS View.
PostPosted: February 8, 2017, 4:00 pm
I think I have about 8 pairs of welding gloves laying around the house. When I was working in Charlotte they made us buy the gloves (me not knowing that was against OSHA) so I would make them last as long as possible. With the new job they buy our gloves for us. I'll wear them for about a month and grab another pair.
PostPosted: February 9, 2017, 10:37 pm
Made it out to the shop after lunch today. Scratched a bit, then started to commit fabrication.
Cut out some .063 pieces for the scuttle with the plasma cutter. Easy peasy. The base will be made from 1" sq .063 tube.
File comment: cutting .063 pieces for scuttle
Put the wood scuttle buck on the car and proceded to tack up all the steel pieces I had cut.
Just a bunch of pics of scuttle with buck removed.
File comment: PS view of scuttle
File comment: front scuttle from drivers side
File comment: rear scuttle from drivers side
Then I pulled out the masking tape and had a bit of fun to see the shape of things to come.
File comment: 3/4 view from right front
File comment: 3/4 view from left front
File comment: 3/4 view from left rear
File comment: 3/4 view from right rear
PostPosted: February 10, 2017, 12:25 am
Ohhhh, looks racey with all those tape stripes.
PostPosted: February 12, 2017, 2:45 am
Yeah, I know, my hair was straight back when I was applying the tape :cheers:
In the shop this afternoon. More work on the scuttle.
Measured and cut 1" sq tube for bottom frame of scuttle.
File comment: 1" sq tube frame on bottom of scuttle
Used plasma cutter to cut a bunch of 1 1/4" .065 strips to put some backbone on the spine of the scuttle. Used the stretcher/shrinker to curve the strips, another tool I wonder how I lived without. No distortion adding these strips to scuttle.
File comment: Stretcher with 1 1/4" strip that I curved for the scuttle
File comment: .065 strip curved to fit scuttle
Cut, stretched, test fit and tacked up all the strips. Scuttle is very rigid now.
File comment: Scuttle frame
File comment: Scuttle frame tacked up
Due to the fitment and size of the OEM instrument panel I'll be placing it in the center of the dash (like build #1). Next project, rework the OEM wiper assembly and heater to fit the scuttle.
PostPosted: February 12, 2017, 8:02 am
Nice work as always, Perry!
So, can you build one more, while you're at it, for my Grand-daughter? She's 10 months old. No rush... :mrgreen:
PostPosted: February 12, 2017, 12:07 pm
Ha! I just found out #6 grandkid is due this fall. I don't know if I have the stamina to keep up in this race :D
PostPosted: February 12, 2017, 9:03 pm
I told ya, Perry. You'll be busier than ever when you're retired. It makes you wonder how you ever had time for a job. :lol:
Nice work on the scuttle!
PostPosted: February 14, 2017, 12:29 am
Had some fun in the shop today, it was mock up time. Made some plywood stanchions, a coreplast windshield, and proceeded to fabricate the windshield wiper assembly. I reworked the parts to adapt to the scuttle. I machined the wiper post ends to take the universal wiper arms from Speedway Motors.
Fabbed up mounts for the wiper posts, made some mock ww arms from wood and the resulting video took place.
https://www.youtube.com/watch?v=He3UtyBXkS0
Just some pics of the mock up.
PostPosted: February 14, 2017, 10:37 am
Nice work on the mock-ups, Perry. I like that your windshield will be tied in to some serious metal. Using a fiberglass scuttle in my own build has been something I'm concerned about in terms of securing it.
It's great to re-use the donor stuff. Stand clear of that lower arm that connects to the motor though. :lol:
Users browsing this forum: No registered users and 30 guests
