It is currently August 12, 2020, 7:19 pm
Post new topic Reply to topic  [ 478 posts ]  Go to page Previous  1 ... 17, 18, 19, 20, 21, 22, 23 ... 32  Next
PostPosted: March 11, 2017, 12:18 am
Went out to the shop for a bit today.
Made up a construction paper template for the dash. Transferred it to 1/4" Baltic Birch plywood, I've used this for the previous 2 builds and am very happy with it as a dash material. Cut out the dash, marked up the placement for the instrument panel, headlight switch, and instrument dimmer switch. Applied some filler wherever the wood splintered. Cut out holes, and used epoxy, hardwood, and screws to mount the switches and instrument cluster.
Just some pics of todays efforts.
File comment: OEM headlight and instrument dimmer switch.
File comment: Instrument cluster mounted centre of dash.
File comment: View of dash
File comment: Instrument panel lights, lights low, sexy!
Next is mounting the heater switch, the pull/push heater coolant shutoff valve, the cig lighter, and 2 power points
Another thought - 8 bolts and a temp floor pan, hmmm, may be a video in the works..........
PostPosted: March 11, 2017, 9:43 pm
Not much to show for a days work.
Worked on the dash board today. Drilled holes and fitted heater switch, push/pull coolant shutoff valve, cig lighter, and 2 power points. Sanded, applied sealer, primer, and then final paint in hammered metal. Painted headlight and dimmer switch black.
File comment: Dash painted hammered metal
PostPosted: March 11, 2017, 10:16 pm
I dunno, Perry, that would be a pretty full day in my garage. I guess that's why you're on your third Locost and I'm still on numero uno. Oh well, what ya gunna do? :roll:
PostPosted: March 11, 2017, 10:48 pm
I could use a couple of slow garage days like that myself. 8)
PostPosted: March 11, 2017, 11:15 pm
Yeah, well I wish I had your computing program skills. I'm still chiseling rocks into wheels.
PostPosted: March 14, 2017, 12:16 am
Made it out to the shop this afternoon for a bit. Cut 2 pieces of 1 3/4" sq tube and worked them into headlight/signal light mounts. Attached them to the frame. Worked on front wiring harness. I now have headlights hi/low beam, front marker lights, left and right signal lights, and horn.
Some pics.
File comment: Headlight mount.
File comment: Soldering 3mm bullets to wiring.
File comment: Lights mounted and wired.
File comment: Lights with nose cone in place.
PostPosted: March 14, 2017, 7:30 am
Yo, Perry-
Those bright shiny rocks you chiselled for the front of the car look pretty good... :mrgreen:
PostPosted: March 14, 2017, 8:32 pm
Thanks JD, I flashback to my younger years watching the Flintstones, man that was quite a few haircuts ago.
Spent the afternoon in the shop. Took the rear fenders and mounted them. Sounds easy, but here's the story.
Measured and marked bolt hole locations for the right rear fender. Now I always drill 3/32" holes prior to drilling whatever the final size will be. I do that because I've had larger or final size drill bits wander as you drill your work and when you try to align holes you wonder where you went wrong. Anyhow, I double checked fitment and drilled my final size holes for the fender. Then transferred the hole marks to the frame, drilled 3/32", checked fitment, drilled final size for nutserts, installed nutserts, and checked the fender fit to the frame. Easy peasy. Now I take the right fender and place it mirror image on the right fender and mark the hole locations on the fender. Then I take the right side frame measurements and mark the left side frame. Take the left fender and do all of the above to it as the right fender. Mounted both fenders, stood back and patted myself on the back. Walked to the rear of the 7 and raised an eyebrow - something didn't look right. The rear of the left fender looked lower than the right fender. Rechecked both fenders for exact fitment to the frame-good, checked frame itself-good, measured the arc length of each fender 58" - good. Put a straight edge across bottom of frame and see that the rear of the left fender is 3/8" lower than the right. Now that's a head scratcher believe me.
So after much thought I believe I found the answer. My 7 is just like a human, and some parts of the human anatomy hang lower than other same parts, that's just the way it is, no matter if my car is male or female.
So to please my eye I removed the left fender and removed 3/8" of material from it. Now my car looks balanced again. And no one will know the difference, except whoever reads this post.
File comment: Rear fenders mounted.
I then went on to mount the rear tail lights and wire them up. I now proved the tail lights, both signal lights, brake lights, B/U lights, and hazard light operation.
File comment: Tail lights and fender view drivers side
File comment: Rear view of tail lights and fenders
File comment: 3/4 view of tail lights and fenders
PostPosted: March 14, 2017, 9:32 pm
I knew this girl in North Carolina, one of her... Never mind, I'll tell you when we meet up some day... :twisted:
PostPosted: March 14, 2017, 9:40 pm
Wow! Small world, I might have known her Northern cousin! :oops:
PostPosted: March 15, 2017, 8:50 am
I think both of you guys are in trouble :ack: if wifey reads any of these post. Dave W
PostPosted: March 15, 2017, 9:52 pm
Did not go to the shop today!
Week ago I ordered the LEGO Caterham 7, waited eagerly for it to arrive. Went to the post office today, yippee!!
Brought the model home, opened the box and commenced building while Mr Seven stood on the kitchen table watching me and advising me on the build. 5 hours later I was done. I set the 7 on the floor and giggled as Mr Seven walked up to the Caterham, got in, and took it for it's first drive! See youtube video, enjoy!!!!
https://www.youtube.com/watch?v=yaUyjZpxUTo&feature=youtu.be
File comment: Building the LEGO Caterham 7
PostPosted: March 16, 2017, 7:56 pm
So, you've got talent as an animator too, Perry? That was a fun little video.
PostPosted: March 17, 2017, 8:49 pm
Made it out to the shop today for a bit.
Purchased a 5/8" bayonet spot face cutter in anticipation of building the front fender mounts. It worked as expected, drilled out a backing plate bolt hole to 1/4" and back cut a spot for a 5/8" spacer and 5/16" bolt.
File comment: 5/8" spotface cutter
File comment: mounting bolt installed after cutting
Fabbed up the base mount for both sides. Cut and welded the fender stand offs.
File comment: fender base mount installed
File comment: fender stand offs
Measured, test fit, tweaked, and tacked everything in place.
File comment: front fenders rear view
File comment: front fender side view
File comment: front fenders front view
PostPosted: March 18, 2017, 8:26 pm
I'll have to come back to this one again, Perry. I'm not quite understanding it tonight. I think that has more to do with a long day wire brushing, welding and grinding rather than your photos or explanation.
Users browsing this forum: Google [Bot] and 4 guests
