Posthumane wrote:
You may be able to package the runner length by having a continuous curve in your runners. It's how I made mine. The runners start horizontal and curve downwards with about a 6" radius bend, so a 90 degree turn results in about a 9" runner outside of the head, plus your flange to valve distance. The runners then enter the plenum vertically from the top.
To reduce your plenum volume you could use a 3" diameter tube cut in half, with a flat piece welded on the cut line to make a D shaped cross section. One advantage of that approach is that it's easier to drill the holes for the runners in a flat piece compared to the side of a large diameter tube.
I don't thin 18 ga sheet metal will dent very easily with all of the curves in it. Mine is made from materials that I had on hand so it ended up being 16 ga runners, 14 ga plenum tube with an 18 ga end cap, 1/4" motor flange and 1/8" throttle body flange.
Believe it or not - but that's what I meant by banana shaped runners LOL
I was thinking D shaped, but a different method of going about it. I was going to cut the holes and tack the runners to a flat piece of sheet steel, then bend the steel around a 2.5" piece of exhaust pipe. it would essentially leave me with a D shape, but with less joints. I'll have to buy a gas bottle and properly mig this. I'm actually looking forward to it. Just need to find someone to cut me a flange!
Tucker
Driven5 wrote:
