The guys doing the demos on YouTube are sponsored usually or someone else picking up the tab. So the cost is of little concern to them.
I was trying to be on the economic side but I did have to order a little more than my original estimate. Lost a chunk on the first attempt to do a rear fender.
Second attempt now using 2 pieces. And the cutting tape. It’s really pretty cool. Hard to get started first but once you get the hang of it it works great. Started by laying the tape on the apex of the curve on the outside edge of the fender. Then laid the face piece on pulling it past the tape enough to adhere it beyond the tape’s edge. Squeegeed that smoothie then trimmed that back towards the tape as much as I dared. Then laid the top piece on, pulled over the tape. Smooth down and
trimmed off excess. Then I pulled the tape and it cut both layers of film leaving them butted against each other perfectly. Squeegeed the joint smooth.
Pretty much the same technique or the nose panels.
Not as nice as using one piece would be but I just don’t have the skill to do that and am not a good candidate to learn. Don’t think I’ll try it again unless this one fails.
Hope this is of some help.
Fender
Nose cone
Six feet away
Front
