It is currently April 19, 2024, 4:44 pm
Post new topic Reply to topic  [ 82 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: July 17, 2016, 11:02 pm
I called to schedule the inspection, and they had a cancellation for tomorrow, so I have been busting my rear to get it buttoned up.
Trunk sides and bottom
as she sits now:
If you have time to clean your shop, you don't have enough interesting projects to work on.
PostPosted: July 17, 2016, 11:17 pm
Best of luck to you. It looks great.
PostPosted: July 20, 2016, 12:25 pm
Passed inspection, got the title and VIN paperwork in motion!
Just a little bit more red tape and she will be on the road!
PostPosted: July 20, 2016, 1:32 pm
Congrats! The car looks great.
PostPosted: July 20, 2016, 3:45 pm
Yes, congratulations indeed.
PostPosted: July 20, 2016, 10:53 pm
Finished the trunk
PostPosted: July 23, 2016, 9:02 am
Good job! Hope to see your car in person.
Gale
http://www471.pair.com/stalkerv/gallery ... emId=23737
http://www471.pair.com/stalkerv/gallery ... emId=28999
PostPosted: July 28, 2016, 11:16 pm
Weighed the car using a bathroom scale, some 2x4s, and a 5' chunk of c-channel for a lever. Came out to 845 (52%) on the front, 780 (48%) on the rear, 1,625 lbs total.
Not sure how accurate it is, I will probably still end up going to the truck stop and use a certified scale at some point.
PostPosted: July 29, 2016, 7:56 am
Hi Lux :mrgreen:
Great lookin' car, and legal too! Cool!
Congrats, Bro!
JD
PostPosted: August 11, 2016, 10:20 pm
Sometimes, it really is better to be lucky than good. I tried finding information on the internet about connecting a GM style speedo to a Toyota transmission, or a Japanese transmission of any kind. I couldn't find any info at all, so I figured I would find out the hard way how to make it work, and if the drive ratio was anywhere close.
GM Speedos use a 5/8"-11 thread on the back with a 1/16" square drive, like the Speedway gauge set I am using:
The Toyota trans uses an M18 thread with a round drive and a crimped 'paddle' drive, which is common among other Japanese transmissions, including early Miatas:
The speedo cable for the 1979 Toyota Pickup donor utilized a square drive on the speedo end, but has a simple clip hook that hooked into a groove on the back of the speedo:
It turns out, that this hook setup will snap on to the 5/8"-11 thread of a GM speedo and the square drive will spin the speedo!!!
The icing on the cake: the speedo reading is within ~2mph of a cell-phone GPS speed reading!!! That's as good as a factory car!!!!
PostPosted: September 27, 2016, 8:47 am
300 miles on the car now and I have made a couple changes:
1. I replaced the glasspack muffler with a Jones turbo-tube muffler. The glasspack was way too loud for right next to my ear, and it sounded like a rice rocket over 4k which was the dealbreaker. The Jones is the same size and shape as the glass pack, so it didn't require a complete rework of the exhaust. I would recommend this muffler to anyone for a locost application.
2. When I was replacing the muffler, I welded in a fitting for an 02 sensor. I used an inexpensive unit with a bosch wide band O2 sensor and zip tied it to my brooklands temporarily. The wide-band is the ONLY way to tune a carburetor, and has made a huge difference in performance. I have a better chance of reading a crystal ball than reading plugs accurately for all RPM ranges which a lot of people think is good enough.
3. The one-piece hood is a giant air-trap and would cause the engine to run way too hot at speed. At idle, the engine would sit at 180 and then at 60+ it would hit 230. I pulled a dzus fastener on each side of the hood and stuffed a rolled up work glove in on each side to get it home, and the 1/2" gap the glove created dropped the engine 30 degrees. I cut some louvers out of a machine stand panel I had and bolted them to the hood to prevent future issues.
PostPosted: September 27, 2016, 9:15 am
I'll 2nd the the Jones muffler! Better then your typical glass-pack, plus they are avaliable in longer lengths and larger Diameters. I still ended up adding a baffle, in the tail pipe.
Great looking trunk :cheers: :cheers:
You might also want to look at adding ducting for the rad.
Dave W
PostPosted: October 3, 2016, 9:48 pm
as she sits now:
Are these from Fenders N' More?.
Steve
PostPosted: October 4, 2016, 1:07 pm
The rear fenders are, yes. The fronts are from etrailer. Big difference in price.
PostPosted: October 4, 2016, 3:23 pm
Can I ask what you paid for them? I assume their aluminum?
Steve
Users browsing this forum: No registered users and 29 guests
