Lots of progress since last time. It's basically a kit car now with everything fabricated and loosely bolted together. This is the way you would hope to receive a real kit so maybe just arriving at the starting line but pretty happy with where it's at.
I thoroughly cleaned the garage this afternoon getting ready to start taking it back apart to finish and paint everything. It came together at the end a lot faster than I expected. I've got a LONG time before it's back together in finished form but having no parts left to bolt on feels pretty awesome! (minus a few small things that will be easier with everything apart, headlight install, etc.)
Passenger seat is still stuck in the attic.
Uh, this was
before the garage cleaning.
Still loving the home powdercoat kit!
Small heater for the footwells and a basic defroster:
Electronics hardware mounted, no wiring yet, I'll do that on final assembly. The panel is mounted to the frame on rubber isolators and pretty easy to remove, I'll put some bulkhead connectors so it can come out for any major repairs. I was sweating how to get the battery down low and then it showed up in the mail. I went with LIon and it probably weighs less than the megasquirt controller so right on the board is way easier.
Ducting for the radiator, glassed into the hood now.
So, now I need to pick finishes for everything (not trivial), finish weld a lot of things I couldn't reach except to tack (including the whole header), paint and put it all back together...and wire it (300ish circuits, ugh.)
Mostly relieved that there's not too much to worry about anymore, all major 'will this work/fit?' challenges are behind me. Windshield will be a struggle but it's not complicated, just fussy. Dash is pretty easy but I need to go through the motions of mounting everything. The roof can wait until I'm on the road.
I'm still a full year away from when I planned to be done so feeling pretty optimistic at the moment.
Alex
