It is currently January 17, 2019, 1:30 am
Post new topic Reply to topic  [ 135 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 9  Next
 Post subject: Re: marafonets design
PostPosted: December 21, 2017, 11:00 am
Excellent work !
What type of bender did you use for the suspension tubes ?
PostPosted: December 21, 2017, 11:15 pm
niko wrote:
Excellent work !
Thank you ))
About how I bent the pipe on the suspension. I can tell the whole story. Firstly, I used a steel pipe with a one-piece diameter of 25mm wall of 2.5mm. Secondly, the bending radius of the pipe is 50 mm. This is the radius I drew well, just because of the beauty. That in the manufacturing process brought me a lot of problems.
To begin with, I went to friends who build motorcycles they had a regular pipe bender of this type. In general, I immediately got a pipe room with a flattening. In the photo below I will be an example.
Then I began to puzzle how to make a bend? I refreshed knowledge, read books, looked at technology. And I decided to make a pipe bender of this type. It is universal and then useful for other works. But because of its versatility, it is difficult to bend a pipe with a small bend radius. I had to make such a small roller and 2 mandrels. In general, see the result on the photo.
Do not be ashamed not to know, it's shameful not to know and not ask
"And even if they say " Yes, let them talk!
But no one - no one dies in vain,
This is better than vodka and from colds.
Others will come, replacing comfort
At the risk and inordinate work,-
Will you not passed route." V.S. Vysotsky
PostPosted: December 24, 2017, 8:00 am
Good day to all.
Finally, the turner cut out the cones and seats for the nozzles. And this weekend I started assembling. First, I printed out the sweep of the surfaces. Then I applied and turned the lines of the cut. Then I cut off all the excess on these lines, and everything got up as it should. Then I weld all the details. Tomorrow I will clean up the protruding places.
The result was an intake manifold. Throttle valves from Toyota Levin motor 4age.
PostPosted: December 24, 2017, 9:34 am
Nice job!
PostPosted: December 24, 2017, 2:51 pm
Impressive in both design and execution. Keep posting!
Larry in Seattle
PostPosted: December 26, 2017, 12:04 pm
Hello everyone, and with the last Christmas.
I thought for a long time about how to make a gas cable drive. Many watched different options. Then I built a 3d model, superimposed kinematics. There was little space inside the cockpit. I had to take him out for a motor shield.
Look, maybe someone will be interested.
P.S. thanks for the support.
PostPosted: December 26, 2017, 1:36 pm
Amazing job so far
PostPosted: January 24, 2018, 9:46 am
Hello. At us a frost a minus 30 already the second week keeps at night happens 40. In garage it is cold so that work while stopped.
PostPosted: February 8, 2018, 11:47 am
Good day to all. I have not written for a long time since we had severe frosts and I worked very little. But I managed to do something. The first is a major engine repair. A complete set of boring of the cylinder block, new pistons, easier connecting rods, etc. The cylinder head was made to me by a nice guy, it's porting channels, lightweight valves, etc. (If I'm interested in detail, I'd like to make a second one for the gas tank. The third one started to lay the brake line. I bought such tanks on the Internet, and they are trying to install a large one. One line does not work. Need your opinion as it looks from the outside, beautiful or not? And he ordered a lot of small details from the turner, I've been waiting for a whole month to do it. Oh, and here I decided to print the nose fairing on the 3d printer. Also a whole month is printed.
PostPosted: February 8, 2018, 12:17 pm
That's very innovative use of a 3D printer in creating that nose cone. I wish I'd have thought of that.
PostPosted: February 8, 2018, 4:21 pm
That throttle cable design is pretty cool. Nice nose cone too - makes me wish I had a 3D printer! Add that to the list - mill, lathe, 3D printer...
Is there a way for you to check the spray patter from the injectors? I would wonder about it because of how high up they are, if that makes sense.
Very good work!
PostPosted: February 9, 2018, 1:53 am
Very good work!
Possibility to check up a torch of splashes is. But even if that not so I will not alter. At us such collectors are made on sale, but you would see what horror there do. There nozzles almost vertically stand.
PostPosted: February 10, 2018, 11:52 pm
PostPosted: February 11, 2018, 9:41 am
Before you weld up the gas tank, add a couple baffles, dividing the tank in 1/3's. You may even want to consider adding hinged gates to the baffles leading into your center fuel pump area. I learned the hard way and had to add a sump because I only used one baffle in my original design. Dave W
PostPosted: February 16, 2018, 11:57 am
Yes, of course, I want to do in the tank against the overturning partitions, as in the book.
So, today for the first time in a week I got to the garage and immediately ran to try on the nose fairing. I got up almost perfectly. And I also bought a radiator from Honda Civic. Even today I took the parcel with a light flywheel!
