Thanks Nick. I have gotten some very good responses on the MG web site already!
So today I decided to see how everything will fit. I first set the trans in roughly the right spot. Then I set the motor in. That showed me that I had a few points of conflict with motor, trans and frame. SO I juggled it all around until I had the motor level, no contact between the power train and the frame and item could be serviced in the future.
In answer to your comment about the frame design, as far as I can confirm, the builder started with a McSorley 442 design. The motor will be just about 1/2" above the bottom of the frame. The shifter is a bit too forward, but if I heat and bend back the shift handle (more like an Alfa) it will be perfect.
The valve cover will be above the engine cover. I played around with the scoop I had and if I turn it around, It will fit over the valve cover and exhaust out to the rear- I think this will actually aid in airflow out of the engine compartment. And I kind of like the look!
As far as the carbs, I am thinking more about converting to EFI now. It would clear the hood and if (as I am thinking now) I go from 8.0 compression to 8.5 compression, a upgraded cam and a little head work, I will be able to get a little better tuning available. The SU crbs w/o the pistons are about the same size as the EFI throttle bodies from Borla mounted on an intake set up for HS6 carbs. They are a bolt on for that manifold!
I am going to "steal" your motor mount design Nick, if I may. It looked plenty strong.
Thom
