Miatav8,MstrASE,A&P,F wrote:
There should not be a cross tube at the bottom of the bell. It should have been cut out eventually but it is handy to have up to a point when building the frame. Don't be concerned about moving the engine forward. Here is a pic of an original with the engine buried in the nose.
It looks like you are using iron channel for the engine mounting. You may want to stick with something more malleable like steel round or square tube. A load spreading base plate and some triangulation would help too.
MV8- Interesting that you mention removing the cross tube under the bell housing. I kept looking at it and was thinking "Do I really need it there?" Please take a look at the photo below and confirm that this tube can be removed. If removed, I could lower the motor in its current location without substantial changes.I would only remove it (of course) between the two foot wells.
Also, I played around with some more practice welds, it appears that I did not clean off the material well enough before I started to tack weld. Its been over 40 years since I last welded in A&P school! I've killed too many brain cells since then!
I have about 5 to 6 inches of clearance for my frame now and the bottom of the pan is 1 inch above the top of the lowest tube as it sits. If I remove the tube under the bell housing, I can have the pan protrude below the bottom of the frame about 1 inch. I think that is more than enough clearance. I do prefer the motor to be back as far as it s for a couple of reasons. It gives a better balance, front to rear, and it locates the shift lever in a good location.
I did use square tubing for the support tubes. I can see how it would look like angle iron in the photo. The photo above only has one of the tubes in place on the passenger side at that moment. Here is the final design as shown on the driver's side.
I was thinking about adding another tube running back and down for added fore/aft stability.
Thanks
Thom
