So today I tacked all the rear end tubes except the curved ones that will be here Monday. I had almost reached this step yesterday, but after chatting with a fellow builder he reminded me that the springs he used (and I'm going to use) will not fit on the stock plate. So I made longer plates and re-tacked the upper side of the diagonal tubes outside the plate's covered area. Now I would like sugestions on how to reinforce the shock towers without bars crossing from one side to the other, as my tank is big and space will be needed for stuff.
Also I've drained the diff oil (more like grease) by the most dangerious method possible. It's held to the table by some wood screws. The oil on the bottle is engine oil, there was almost none on the diff. All of it was covering the entirety of the driver's side brake system. Probably a busted seal. And the car have deep "racing stripes" on the front rotors, so this car was breaking with only one rear wheel, maybe a little with one of the fronts too. It's a miracle it was impounded before being impalled.
