Jim's Mopar A4/W9 LoCost http://locostusa.com/forums/viewtopic.php?f=35&t=2052 |
Page 4 of 4 |
Author: | jrs7s [ May 26, 2014, 12:35 pm ] |
Post subject: | Re: Jim's Mopar A4/W9 LoCost |
Cheapracer: I made the change to the 4AGE since I already had the engine (my daughters old '87 Corolla GTS), and I wanted something more driveable for street use. My daughter also wants to drive the car and I don't think she should w/ the Mopar engine. I also told my daughter that I will give her the car someday. The Mopar engine was very fast, but I always found that is was so loud that it gave me a headache (combination of really loud exhaust and the vibration w/ solid motor mounts). It really needed a bigger radiator, larger fuel tank, larger mufflers, larger tires, better brakes, different ignition system, isolated engine mounts, milder camshaft, and fuel injection. Most of these changes are not really doable w/ the existing car & the budget at this time. I also think I needed a roll-cage on the car w/ the Mopar engine. The Mopar engine is about 230-240 lbs. including the motor plate, water pump, alternator, distributor, intake manifold w/ carb, and dry sump pump. In street legal trim, the entire car was 1,410 lbs. full of fuel w/ the Mopar engine. The AX-15 transmission was also pretty heavy at about 125 lbs. w/ the starter, flywheel & clutch. I have not had a chance to weigh the car yet w/ the 4AGE engine. The car is much more streetable, runs cool, and is reliable enough to drive anywhere. |
Author: | jrs7s [ June 16, 2014, 8:58 pm ] |
I made a new dash from aluminum w/ the turned metal finish. |
Author: | jrs7s [ June 16, 2014, 9:01 pm ] |
I also added air horns to the intake manifold to make the runners longer. I have only driven the car about 15 miles so far w/ this change to the intake, and it feels better w/ a little more torque at low RPM. |
Author: | jrs7s [ June 16, 2014, 9:12 pm ] |
Here is a photo of the drivers side showing the new header & exhaust system. |
Author: | jrs7s [ August 12, 2015, 10:14 pm ] |
A few more photos |
Author: | rdnoel86 [ July 25, 2020, 9:51 pm ] |
Hello, Thread back from the dead.. If you still check in Jim, can you email me at fwdmopar@gmail.com. I have some A4 questions. Ty and what a great build! |
Author: | jrs7s [ June 9, 2022, 9:00 pm ] |
I added a heat shield to the exhaust system. I had to make some brackets to clamp it over the exhaust. |
Author: | jrs7s [ June 9, 2022, 9:05 pm ] |
Recent photos. |
Author: | jrs7s [ June 9, 2022, 9:06 pm ] |
Side view. |
Author: | Kinetic Research [ June 11, 2022, 3:58 am ] |
Wow, impressive condition after a big jump in time, how many miles has it racked up to date? Still running the toyota engine? Superb vehicle. |
Author: | jrs7s [ June 12, 2022, 7:36 pm ] |
Thanks. Yes, I have the 4AGE engine in it. I am not really sure how many miles are on it. I didn't have a reliable speedometer until just recently. I finally have the speedometer fixed with a GPS unit from Holley. It works great. I used 3 different speedometers & senders over the years, but none of the others worked reliably. |
Author: | Miatav8,MstrASE,A&P,F [ May 24, 2023, 11:33 am ] |
Did you consider the 3.9l v6 or 273-318-340-360 family? Too much everything? |
Author: | jrs7s [ June 22, 2023, 2:54 pm ] |
The 3.9L V6 and V8 small block Mopar engines wouldn't fit in the current chassis. I also think they are too heavy and it would be tough to get a large enough radiator in the car. |
Author: | Miatav8,MstrASE,A&P,F [ June 24, 2023, 8:10 am ] |
I understand. More of everything to a fault! My understanding is the a4 block is essentially the same width and length based on the LA series and trans. I expect the heads, headers, and induction would be sticking out (forget a bonnet/hood). A Mopar locost? Those high nickel blocks wrecking my cornering ability? That sounds terrible! Oh, the humanity! Seriously though, I agree no getting around that tiny nose to fit a decent radiator and what you've built would be much more practical and all around efficient. |
Page 4 of 4 | All times are UTC - 5 hours [ DST ] |
