Panhard is "finished" design wise, as with everything is mostly tacked in place but this is likely the end product.
The Pedalbox has been a dreaded detail for quite some time, everything to do with pedal ratio, driving position, and clearances had me worried. The M/C mount is about finished and placement is feeling pretty good, the footwell is cramped but workable.
After thinking about this too much, its been decided to use the sheetmetal firewall as the rear frame and bracing on the Pedals. The side panel was cooked up today and it gives an idea of the shape.
The pedals sit 7.5" off the floor, with the Brake having a pedal ratio of 5.5 and the clutch 4.6, As you may the bolt and shim situation holding the pedals is temporary, at the very least it will get a single through bolt and spacers.
Progress has slowed to 1 day a week as time gets dumped into Work, before starting the thread there had been about 1 months worth of work spread out of 6 months while refreshing a 280z. Ill share these because everyone loves a little Z.
