Hello Locosters; this will be my intro to the LocostUSA members. I've had an interest in performance cars since the sixties. Tried on Lotus 7 for size in 1966, a tite fit. I'm 6-2 and 200 lbs.
I've looked at kit descriptions and pricing and discovered McSorleys frame dimensions and its forward go since then. Lots of study and review, One 1978 Alfa Romeo Alfetta Sprint Veloce dismantled last summer and the first steel cut in Oct. 2007.
July 2008 and this what I'm up to at my house:
--rad mounts reconfigured--- now removable
--chassis floor welded on and chassis painted (Zero Rust) 2 coats
--front suspension and steering rack installed, ball joints fully torqued,obvious re-alignment needed
--fender brackets completed/installed and front fenders mounted
--engine reinstalled Alfa 116 2ltr
--1 shortened prop shaft installed
--rear drive train/transaxle with suspension and inboard brakes installed
--engine plumbed
--cowl completed and dashboard mock-up transferred to 1/8 alum with instruments (Alfa) and switches
--roll bar fabbed and will be off to chromers
--camcover off and will be off to powder coaters (black finish)
--zeroing in on colour...Alfa Rosso Proteo Metallizato
--head lites and front turn signals are hung (H/D and Suzuki)
--rear lites still in the box ("39 Ford)
--all steering shaft joints fully welded where required and removable steering wheel (Momo) with quick release welded on
So its officially (Badges? we don't need no stinking badges! I'm the official cuz I say so,.....and a duster fan) a true assembled roller
Big day
-----next steps
...making it stop.. brake (Wilwood overhead reverse mounted with remote reservoirs) and clutch lines to be run
--hood forming and skinning the chassis
and so on and so on....10 months and counting to date
hope this is not too long winded
I've got lots of pictures to share if any are interested and if I can figure out the procedure (message file size to big)
Regards Wilf, (cfv23844)
from sunny Gabriola, B.C.
