It is currently Wed Jun 19, 2013 5:17 am
Post new topic Reply to topic  [ 271 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 19  Next
PostPosted: Wed Oct 01, 2008 9:00 pm
The drivetrain was removed yesterday. The poor thing has no heart or hind legs.
“Building a whole car from scratch is a 1,000 little tasks, done 1 task at a time, while thinking 10 tasks ahead.”- Locofinn
SCCA D Modified autocross special. Scratch-Build completed 2013.
South Bend Region SCCA http://www.sbrscca.org/
Link to my build log:
PostPosted: Wed Oct 01, 2008 9:02 pm
A well running stock Mazda rotary 12A. Runs like a champ. Great development motor for the chassis.
PostPosted: Wed Oct 01, 2008 9:08 pm
The main reason I'm not getting much done. Me at SCCA Solo National Championships in Topeka Sept 16th finishing the West course. I am co-driving in G Stock. Likely next year also. I hope to have my Seven on track by season start 2010.
PostPosted: Tue Oct 21, 2008 2:40 pm
Hey Locofin,
Love your chassis !!!
Are you still planning to use the Pinto/MustangII spindles ?
What size of of disc are planing to use ?... Your right on the lack of need of big brakes... I know our current setup of 10.25 and Dynalite 4 pistons is a big No...No...with the Diamonds wheels...
Still not sure if I'll be running the locost at the Nationals next year but 2010 is for sure...
Fred
PostPosted: Wed Oct 22, 2008 8:18 am
Yes. Standard OEM Mustang II spindles with Speedway upper adjustable control arms (race stock car parts). Lower arms will custom made.
Planning to start with stock sized brakes also. Just need good pads. Also planning 13x10 Diamond wheels with about 6" backspace. Should fit over stock brakes front and rear and clear the suspension parts.
I am working on the rear axle right now. Just ground off the old bracketry cleaned and painted it this past weekend. It is a stock Mazda GSL with a LSD and i think a 4:10 ratio. The design is a three link with a panhard bar, simple and well suited for what I need. Stock rear disc brakes will also be retained. Only using good brakes pads and braided steel lines along with a dual master cyl and Wilwood balance bar arrangement. I have the Wilwood pedal assy already. I just need to figure out what size master cylinders to use.
Looking forward to getting more stuff done since the solo season is over for this year.
...mark
PostPosted: Sun Nov 09, 2008 10:11 pm
Put motor in the chassis for the first time. It is offset to the passenger side as much as possible. About 65 mm from the center line. Should help with balance.
PostPosted: Sun Nov 09, 2008 10:18 pm
More pics of engine. Note the motor is also set back about 20 cm also. Benefits of of building your own chassis.
PostPosted: Sun Nov 09, 2008 10:20 pm
Hockey pucks for motor mounts. Very firm (and low-cost)
PostPosted: Mon Nov 10, 2008 12:03 am
Be careful with the hockey pucks - I used them on a 914 back in the day, and they ended up splitting after a few track days. It may work for you though. I used them in a tranny mount on a tube frame rear with some plates cut to fit the pucks acting as big washers.
Hope that helps!
Randy
PostPosted: Mon Nov 10, 2008 9:13 am
Randy,
Thanks for the heads up. If I have problems I will go with aluminium solid mounts. I did leave the stock tranny mount rubber isolator intact.
...mark
PostPosted: Mon Nov 10, 2008 9:53 am
What angle will the driveshaft be operated at relative to the pinion and output shaft? Are you using cv joints? The higher the expected shaft rpm, the less the angle needs to be using ujoints.
PostPosted: Mon Nov 10, 2008 11:28 am
Horizontally = 3.179 deg
Vertically = less than 2 deg @ ride height
Fortunately the 1st get RX7 pinion is offset to the passenger side also minimizing the angle significantly.
Being a track only autocross car driven less than 60 mins on track for a season, u joints should last quite awhile.
Should be OK???
...mark
PostPosted: Mon Nov 10, 2008 2:23 pm
I suppose it will be okay for that. If the angles don't cancel during load transitions from deflection in the diff, trans, or engine mounts, the temporary vibration may be pretty bad.
Something else has just occured to me. Are you adding a torque link? With the engine mounts so close together and parallel, the engine and trans will have very little resistance to rocking from side to side without a strong torque link.
PostPosted: Mon Nov 10, 2008 3:46 pm
A torque link would be easy enough to add. Thanks, good idea. Our start launches could get kind of hairy with sticky 10" wide race slicks.
Probably will beef up the u joints too. The drive shaft is custom made anyway.
PostPosted: Tue Nov 11, 2008 7:33 pm
Nice Work Mark,
Offset motor makes a lot of sense for Solo 2 and no passengers.
Keep em comming.
Fred
