rx7locost wrote:
Remember, slow progress is still progress. I have to keep telling myself that.
Right you are, Sir! But then, Mama always said you wuz the smart one in the family...
I did some things last night and today during lunch. First off, I rolled the motor around again and got the same "stop points" as last time. Verified... I put the timing tape on it based on the marks and the new "TDC" point.
Earl brought home my re-jetted carb with the new power valve and various other stuff cleaned up and shiny. I bolted it on the engine last night, checked for gas leaks and found none. So, "being charitable and cautious" (Jimmy Buffett lyric) I started it up. I had to rotate the distributor a bit, but after a couple of tweaks, IT LIT OFF!!! Praise Jay-Suss!!! Idled a bit fast, so I tweaked the idle screw on the carb. Threw the timing light on it, got about 20, so I backed it down to 12. (Spec according to Earl is "10 to 15" at idle.)
Since the water pump wasn't turning and the fan was off the car, I only let it run for a few seconds. (Had the timing light hooked up and ready... Thinking positive!)
Today, I re-installed belts and pulleys and fan and topped up the radiator. Attempted to start it and it wouldn't crank. Then, it dawned on me... It ain't fuel injected now, it has a ol' fashunned carburetor installed. I pumped the accelerator three times, hit the starter and off it went. Still on time and idling about 800 RPM. I let it run for a while... Checking for leaks... None. Checking oil pressure, 50 psi on a warm idle. Coolant never got above 180...
Don't tell nobody, but I think it might be fixed.
Peace, Love and "Fingers Crossed"-
JD, father of
Quinn, Son of a...
Build LogQuinn the Slotus:Ford 302 Powered, Mallock-Inspired, Tube Frame, Hillclimb Special "Gonzo and friends: Last night must have been quite a night. Camelot moments, mechanical marvels, Rustoleum launches, flying squirrels, fru-fru tea cuppers, V8 envy, Ensure catch cans -- and it wasn't even a full moon." -- SeattleTom
