Guess I'm probably never driving the Slotus,
Kristian, if you ever make it all the way down here, we'll get ya in there somehow! Cutting torches and/or surgery might be required, but we'll make it work.
Race Report:Nothing broke, fell off or caught fire. It was a GREAT day! The car made 7 timed runs, had good oil pressure, ran strong (barsturd pulled good up to 6K rpm numerous times!), no sign of fuel injector/ignition problems, etc, etc.
Externally, the car looks good. Not much body roll, stable on corner entry, a little loose on exit which is made worse by getting on the power (Not that I'd EVER get happy on the loud pedal or anything...), brakes are good... But still... Not quite there... I was mid-pack time wise, maybe in the bottom 50%... DAMMIT... Internally, you get a definite impression that the rear end is not gripping as it should. Little slip-slides and wheelspin on exit. Even in 3rd. We played with tire pressures and made it a little better, but not much. (I should note it was a "cold" 60 degree day, and the tires barely got warm.)
James drove the car once, on a "non-official" run and his raw time was about 2 seconds faster than my best. He hit a couple of cones, however, so officially slower. He said the car was better than it had ever been, although he thought there was some "loose" on corner entry that I ddin't feel. Different styles, maybe, or he's got a more sensitive bottom... Uhhh, never mind, I don't want to think about Earl's bottom...
We both think a bit softer rear springs might help the grip back there. I'll be trading out those 400 lb/in coils soon. Otherwise, I think the problem with the car overall is the goober behind the wheel. More seat time! That's the ticket!!!
TWWTFM says I have to "get moving" now, so I'm outta here! Talk amongst yourselves until I get back...
Peace, Love and "Loose Rear Ends"-
JD, father of
Quinn, Son of a...
Build LogQuinn the Slotus:Ford 302 Powered, Mallock-Inspired, Tube Frame, Hillclimb Special "Gonzo and friends: Last night must have been quite a night. Camelot moments, mechanical marvels, Rustoleum launches, flying squirrels, fru-fru tea cuppers, V8 envy, Ensure catch cans -- and it wasn't even a full moon." -- SeattleTom
