It is currently February 23, 2019, 12:56 am
Post new topic Reply to topic  [ 176 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9, 10 ... 12  Next
PostPosted: April 20, 2018, 2:43 am
Lonnie-S wrote:
Was that engine slanted like that in the Toyota donor?
Hey Lonnie, yes, it's a slant 4 and because of that has proved to be a challenge to shoe horn into the frame/body.
The way I look at it is that it's practice for building the Super Slant Six 7, you know, practice at a smaller scale then move up to full size :lol:
PostPosted: April 20, 2018, 11:10 am
Take your time Perry, I want to be the first to build a Slant 6 Locost... :lol:
PostPosted: July 10, 2018, 4:40 pm
Another thread I've read start to finish; amazing transformation! (I love Topolino's BTW) Can't wait to see more!
PostPosted: July 23, 2018, 10:55 pm
Vacation over, back to retirement work.
Bit of a build up date.
After trying to fit the OEM steering column to the R&P with 5 u-joints and 3-3/4" heim joints, I was not happy with it.
So I ordered a 28" Hot Rod auto tilt sterring column. Started fitting it today. 2 u-joints and 1 heim should do the trick.
It has the column auto shift selector, tilt steering, signal light switch, and 4 way flasher switch. I'll be using a shift cable from the column to the auto trans.
I will be moving the seat (I'm making a bench seat instead of buckets) about 4" rearward from the original seat placement. This will eliminate the rear seat that was in the car, will allow me to move the firewall back, and allow me to place the fuel tank in the rear of the car instead of front of dash.
File comment: Steering wheel view
File comment: Steering column lower shaft view
File comment: Steering column PS far view
File comment: Steering column PS close view
PostPosted: July 24, 2018, 9:48 am
horchoha wrote:
Vacation over, back to retirement work. . . .
Wait a minute, Perry. Up there in Canada, you get vacation and retirement? How'd ya do that? You guys up there!
The build is going great. It's going to a unique and fun when you get done with it.
PostPosted: July 24, 2018, 10:14 am
Really glad to see a unique little Italian car saved by any means possible. It really is tiny, isn't it?
PostPosted: July 26, 2018, 5:50 pm
:D We have to, we only have 5 months outta the year to do what you guys down south have a whole year to do :cheers:
Yes, yes it is, it has the same cockpit width as my Silvaire Bushmaster airplane that I built a ways back, 42".
Soooo, wifey came out to the shop for a vroom, vroom moment (years ago it would have been for somethin' else very quick :D ).
Anyhoo when it comes to the build, a happy wifey is a happy lifey.
File comment: Vroom, vroom 1
File comment: Vroom, vroom 2
PostPosted: July 27, 2018, 12:24 am
Looking good. It's going to be a hoot to drive. Plus, so few people will know what it is that you're bound to get tons of questions everywhere you go.
PostPosted: July 27, 2018, 8:28 pm
So yesterday evening I had a great BS session with JD via WhatsApp, nice app that lets people talk or video call each other anywhere in the world.
Today I started fabbing up the brake pedal assembly on the mouse. I looked at Lonnies fabricated pedals and liked what he did.
Another bonus this afternoon, I talked to Lonnie by phone! We discussed pedal ratio's, MC bore size and stroke, and overall design.
It's great putting voices to guys I've been conversing with over a few years :cheers:
Just some pics of this afternoons progress. I'm using the Toyota donor MC.
File comment: MC assembly view 1
File comment: MC assembly view 2
File comment: MC assembly view 3
File comment: MC assembly view 4
PostPosted: July 27, 2018, 8:43 pm
Yes we did! Thanks for 'calling' Perry.
I'm glad to see that Mrs Horchoha is already enjoying her new car. :mrgreen:
PostPosted: July 27, 2018, 11:35 pm
The pleasure was mine, Perry. I enjoyed talking with you.
The brake pedal is coming along!
PostPosted: July 31, 2018, 1:34 am
Welded up the brake pedal assembly. It is a stand alone unit. It will bolt to the car frame and will go through the firewall where the master cylinder bolts to the assembly. Still have to fab up a stop light switch on the assembly, drill mounting holes in base plate, ordered a longer rubber foot pad and new master cylinder. Never mind the assembly bolts, the proper Gr 8 bolts and ESNA or Stover nuts, most likely Stover nuts will be installed on final assembly. Stover are lower profile.
When I drew the pedal pattern out on construction paper, I put the push rod pivot behind the brake pedal pivot. As you press on the pedal this allows the push rod travel 'arc' to start below the centreline of the master cylinder piston, halfway pedal travel, the push rod is centreline of master cylinder piston, full pedal travel, the push rod is just above centreline of master cylinder piston
Some pics.
File comment: Rod end and push rod
File comment: 3/4 view 1
File comment: 3/4 view 2
File comment: PS view
File comment: Rubber stop bumper
PostPosted: July 31, 2018, 7:43 am
Nice work, Perry... Very nice, as usual.
On the Slotus, I built my own gas pedal assembly. I bought a Wilwood brake pedal assembly. It's one thing if the gas pedal breaks and the car won't "go"... It's another thing entirely if it won't stop!
"A man's got to know his own limitations." -- Dirty Harry
Peace, Love and "Whoa, Camel!"
PostPosted: August 9, 2018, 11:20 pm
So....I opted for a larger pedal pad, 3"W x 5"L. Now I can brag that mine is bigger than yours. Some pics
PostPosted: August 10, 2018, 2:53 pm
Looks great. It may even be large enough for snow boots. :wink:
