No sorcery here
Dont mean hi jack the thread
Since you asked, here is how I used this "primer" in the pink-insulation foam plug construction.
Pink insulation is glued together, use Gorilla Glue. And then it is rough shaped with rasp, 50 grit sandpaper/ orbital to get the surfaces kind of on the same level, but still very rough.
Then you can see the primer can I used Zinsser Fast Prime 2, I just pick a random sandable primer, nothing in particular. I use the entire quart, layed it on think. This was so I had a good base layer that I could sand on and build on top of.
Then I sprayed a light coat of black spray paint on top so as I sanded the top layer (with long sanding block), the low spots would show black so I could easily find them and fill them with body filler. (I like using the Icing body filler because is sands much quicker than bondo) (this is the most time-consuming part)
Then once most of the low spots are filled and the surface is pretty even I then apply the expensive stuff, Duratec Grey Primer. Spray in on thick a few coats and if desired you can sand it down to get a more level surface. The last layer of Duratec I spray on a fine mist and dont let it wet out, that way it gives the textured plastic molded look.
At this point you can put on your mold release agent, gelcoat, fiberglass and polyester resin to make the mold.
Once the mold is done, make your part, pull it out, trim it and throw it on the car, easy peasy.
