It is currently Sun May 19, 2013 2:33 pm
Post new topic Reply to topic  [ 42 posts ]  Go to page 1, 2, 3  Next
 Post subject: Chuck's K24 Riot middy
PostPosted: Sat Jun 16, 2012 12:53 am
Finally recieved my Sylva Riot from England yesterday.
Plan is Honda K24 motor, powerglide auto and the rest will be as published
Starting dummying stuff up mainly to make sure I got all the bits
 Post subject: Re: Chuck's K24 Riot
PostPosted: Sat Jun 16, 2012 5:09 am
allmtr wrote:
powerglide auto
Eh??
Was that a joke for another performing forum ...?
Nice simple design/layout, good luck with it.
PostPosted: Sat Jun 16, 2012 5:19 am
Nope, I'm running a 'glide with a Gates belt drive setup
PostPosted: Sat Jun 16, 2012 7:37 am
So you're going to longitudinally mount the engine I presume and go ala "Big GT40"
You know the one;
http://www.gt40s.com/forum/gt40-tech-po ... 00-hp.html
Why don't you just use transverse and the Honda auto?
PostPosted: Sat Jun 16, 2012 8:50 am
Sorrys guys, I've put this in the wrong section, it should be in with the middies.
Cheapie, no it will still be transverse with a glide beside it and belt drive to the rear end. Honda auto won't take the power I'm planning
PostPosted: Sat Jun 16, 2012 9:20 am
Then adapt it to a GM 4T65E-HD auto and save all the hassle - also have equal length and strong driveshafts, big brakes etc, save a lot of money using junkyard bits.
Has advantages like final drive ratio easy to change (sprockets and chain), known tricks and upgrades etc.
PostPosted: Sat Jun 16, 2012 5:55 pm
I love thinking outside the square ...but im having trouble with this one :shock: will the powerglide be a shortened one like they use in speedway ?
Kiwi Dave
PostPosted: Sat Jun 16, 2012 7:25 pm
Yes
Very early in development as I needed the chassis to work out fitment.
PostPosted: Sun Jun 17, 2012 11:25 am
I'm interested to ask where the drive goes from the trans output to rotate the axles (axle?).....
 Post subject: Re: Chuck's K24 Riot middy
PostPosted: Mon Jun 18, 2012 8:01 am
The drive will be returning to the centre of the car via a shaft where the 1/4 extension is, then belt drive down to a toothed pulley mounted on a Cressida differential. It's going to take a ton of time, effort and money :/
Got quoted $300-350 to get the frame sandblasted and powdercoated today which seems pretty good :)
PostPosted: Mon Jun 18, 2012 9:16 am
I presume you are aiming for Oz fastest street car or World's fastest Kit-Car?
Chasing 0-60 or 1/4?
Your layout is pretty simple, why the big cost?
PostPosted: Mon Jun 18, 2012 9:34 am
Hmmmm...... One piece flange on the pump drive and a foot operated bypass valve on the line pressure circuit?
Old school but effective :mrgreen:
PostPosted: Mon Jun 18, 2012 10:06 am
Not really after titles just something quick. The twin of my motor makes a little over 1000hp...
The big cost will be the bellhousing/diff carrier which will be CNC machined out of one (huge) piece of alloy.
PostPosted: Mon Jun 18, 2012 12:46 pm
Well that's a choice, you could make a spaceframe - there are actual bellhousings around made from spaceframes and certainly plenty of BEC diff carriers.
This is often a prefered method in the aircraft and aerospace industry.
Make a spaceframe first and cure any issues then look at that CNC billet route if you feel the need, if nothing else it would make a good test run to make sure everything is correct.
PostPosted: Mon Jun 18, 2012 2:06 pm
Why not buy a proper dogbox instead of starting from zero?
