I appreciate your concern. As I have said before, Oklahoma is extremely easy to get a home built car tagged. The "inspection" process basically consists of taking your car to the tag agency so they can see if you've attached your state issued vin in the proper place, ie there are really no equipment regulations for a one off vehicle. Heck you should see some of the pieces of crap that roll around here! I once saw an old dodge pickup that had the frame stretched about 5 feet between the cab and the bed, for no reason and there was nothing inbetween, just air
I'm sorry if I sound ignorant or cavalier about the issue, I do realize that cars need both a parking brake and an emergency brake. But sometimes it's easier to comply with the spirit of the law than the actual letter of the law if you know you can get it legal either way.
rx7locost wrote:
I have had bad master cylinders (which would leak any pressures created from another pressure source) failed single-circuit systems (Which I have already mentioned) and rusted out brake lines (also would not be good on a hydraulic emergency/parking system) Even if hydraulic emergency brake is OK, a totally redundant system is required whether mechanical or hydraulic. I'm sure that you can share a brake disk between service and emergency brake systems.
I know it is possible to use the service brake and e brake on the same disk as my s2000 uses this type of setup. It uses only one caliper. The emergency brake cable attaches to an arm on the back of the caliper that pushes out on the piston. It's a system that works well but it's heavy and bulky! I will look into what I can get for an actual emergency brake. Part of my apprehension it my attempts keep the "parts" side of the budget to under $1000
