Miatav8,MstrASE,A&P,F wrote:
After it is driveable with some nice empi 5 lug street wheels, tires, and a pertronix, it would be a lot easier and cheaper just to turbo and efi the aircooled vw motor and upgrade the swingaxle to irs and the king pin to balljoint along with discs all around if you wish.
You could cut the king pin lower tube for an adjuster for now, then cut the beam out later on and bolt-in a balljoint beam.
An 80s rx7 turbo rotary adapted to a vw bus transaxle would be a nice combo for track use.
Is this to be dragged to the track or street driven with a reasonably low highway cruising rpm?
Samba is an excellent source of information on vws:
http://www.thesamba.com/vw/forum/viewtopic.php?t=212747If you really want subie power numbers and be able to put them down on a circuit, you might as well start from scratch and sell this to someone who likes old school vws (like me).
A Few Notes:
VW Bus transaxles have gearing that isn't optimal for track use.
The VW Balljoint beam will not directly swap on framehead in place of Kingpin beam - the center to center distance of torsion tubes is different. You'll need to swap the frame head...
bnc
