I feel like I'm on a roll. I did some seam sealing in the boot area and gave it another coat of Rust Encapsulator. Thats all for now. it will get finished with bed liner much later on.
I next worked on the gas pedal. I got into this issue when I decided to cut, cut, cut the trans tunnel where it meets the foot well in the engine compartment for clearance of the ear on the transmission itself. In hindsight, I should have cut the ear off the trans. Hindsight is 20/20, if we are lucky.
That move eliminated the OEM pivot of the gas pedal. I had to reconstruct that in a different manner. The notched corner required that I move the location rearward just under 2 inches. The ferrule that the throttle cable goes thru had to be rotated 90 degrees in order to move it that far. I ended up cutting a section out and replacing it with new because there were too many welded nuts from the OEM mount getting in the way.
I have it in place now with barely enough space to run the pedal shaft between the lower steering column mount and the trans wall.
Moving the entire mechanism had a drawback, without any further modifications, the gas pedal is now moved that 2 inches rearward toward the driver.
I attacked this problem and made some geometric adjustments to the gas pedal to move it to align better with the brake pedal and get it a bit away from the trans tunnel. All good now with that.
That created the next issue, that of the two pedals being too close to each other. Couple of partial cuts to the brake pedal, a bit of adjustment and rewilding and voila. With my shoe used as a SAD (shoe aided Design) to verify the finished product, I claim that project done.
I also finished the welding on the fuel pump cover and have it primed.
Next update is the replacement sway bar.
