Miatav8,MstrASE,A&P,F wrote:
Hooray! The best rwd v6-60!
One thing is that induction system came after the non-electronic 700r4 was phased out so it will be interesting fitting the tv cable for the 200r4 though I’m sure you will figure it out.
I had to replace the ps pulley on mine. It was bent a bit from the donor s10 accident.
I won't have to replace the pully. it is non-existent. I was planning to delete the PS pump anyway:mrgreen: Maybe those pulleys are just very fragile and get bent easily, as in an accident like yours, or just a bump or two when pulling the engine? If I go with power steering, I will use the electric PS in the steering column. Still not sure If I will do that or not.
I spoke extensively with a guy who does many MGB engine swaps in his shop. He even sells V6 installation kits for the MGB. Originally I was focused on the 2004R due to a lot of reading. It has some small advantages in gearing ratios. Plus I was thinking I might go the megasquirt route for engine control. If I did, then I figured I would need a dumb transmission, which the 2004R is. Otherwise I would need a separate trans computer. (think more $$). SO that was my interest in the 2004R. I now have the engine and all wiring. I have now decided to use the GM ECU with some necessary software mods. With the GM ECU, the 4L60E can be controlled just as it was in the Camaro.
130K mile Engine, starter, alt, PS pump, A/C compressor, Ex manifolds, exhaust pipes, O2 sensor, coil pack, Wiring, ECU...….. all for a mere $90 plus gas and time. I'm retired. I have time. How could I go wrong? Even if I end up scrapping it and getting a FWD 3400 engine, I would need the RWD timing chain cover which is a few bucks by itself. Not all would be lost.
Anyone want a 2004R with a new master rebuild kit (plus...)?
