It is currently May 3, 2024, 10:22 pm
Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2
 Post subject: Re: BEC Willy's Build
PostPosted: October 28, 2020, 9:27 pm
Next episode is up on YouTube everyone! Working on the radiator ducting this week.
https://youtu.be/EfTttxpE6sM
If it’s not custom, I don’t want to hear about it!
Youtube Series
Willy’s Hayabusa Build Log
PostPosted: November 4, 2020, 10:24 pm
Getting work done! In this episode I finally finish off the radiator ducting to the flat floor. More work than I thought for sure.
https://youtu.be/Y1_fZFTBM-I
Youtube Series
PostPosted: May 8, 2021, 10:17 pm
So it’s been a while since I updated everyone here again. First up, here is a great rundown video showing exactly what I’m building and why.
https://youtu.be/2Xc52CVDnd0
Youtube Series
PostPosted: May 8, 2021, 10:20 pm
Next up was installing the dry sump pan in order to check clearances....
https://youtu.be/WwJ9hE7A4Nc
Youtube Series
PostPosted: May 8, 2021, 10:22 pm
Next I made some brackets to mount the seats...
https://youtu.be/gpG6CMXYwHI
Youtube Series
PostPosted: May 8, 2021, 10:23 pm
And then I had to build everything for the steering rack to sit where I could fit it, unfortunately that meant on the wrong side...
https://youtu.be/6GBlhRRr3UU
Youtube Series
PostPosted: May 8, 2021, 10:26 pm
And finally, I got to making the driveshaft again. Lots of research on this part, decided to go with high speed cv’s on both ends due to the extreme rpm and compounding angles (although very slight)
https://youtu.be/lUDGzMiAUv0
Youtube Series
PostPosted: May 8, 2021, 10:30 pm
And now I managed to mount the rear transaxle, build the rear control arms, and get all the suspension assembled and in place! Starting to look bad ass!
https://youtu.be/GuCGQx0xfqY
Youtube Series
PostPosted: July 6, 2021, 7:13 pm
Well, after building the rear suspension I went on to pedals. I wasn’t able to build them entirely, just get a good start on them until my master cylinders come in.
https://youtu.be/czljd7u4o0c
After pedals were built I revisited my steering setup. I was concerned with the angle between the tie rod and the steering rack when looking at the outside tire. The angle would have likely bent something so I decided to move it as far as I could towards the rear. While apart I also made new sprocket adapters to run double chains, and a tensioner to keep everything taught. This also required me to make new brackets on the uprights to reposition that mount, so I made them with adjustable height as well. That way I can get the bump steer perfect.
https://youtu.be/vo_r0d6O_3g
Youtube Series
