Newt wrote:
Miatav8,MstrASE,A&P,F wrote:
CCrunner didn't like his T5 and removed it later on; not sure why.
Why shorten the tail end of the t5 when there should be plenty of room between the pinion flange and the t5 for a driveshaft or even just a single joint and slip yoke? Trying to free up some seat space with a narrower tunnel?
That is exactly right. Weight reduction is a nice benefit as well. I started setting seats and transmission in it and very quickly ran out of room. Also shorter transmission decreases the operating angle of the driveshaft. The space constraints ccrunner is dealing with in his Berkley is ridiculous!
I'm not going to dig back through his N600 build because it's so long but if I remember correctly he didn't have his ratios sorted well between the T5 and the differential and he also had a severe vibration. He could answer that better though.
Hey Newt..
The lessons learned from my T5 experiment were these: It will 'technically' work, and on some level it's worth the effort.. In my case the input shaft was slightly bent which gave me an intolerable vibration, but other than that, it was a sound design.. It was initially really nice to have an integrated reverse and .73 overdrive
It did end up proving to be a bit of a redundancy however with all of those gears (6 bike gears + 5 T5 gears) from which to choose.. I found the VFR motor wants to be up past 5K at least to make any power, and the T5 gear spread was such that eventually I left the T5 alone, and did all of my shifting through the close-ratio VFR tranny (truth be told the VFR box was simply more fun to shift/drive.. using the T5 always felt slow/lazy).. It was at that point that I ditched the T5.. Pulling it removed my self-inflicted vibration issue, and it also removed 70lbs from the car (it was also at this point that I the car 100% needed a Guibo, so I was up for a redesign anyway)
.. I came to rationalize that I didn't really 'need' reverse (you don't on a BEC, it's just nice to have)- and I never looked back..
I can't remember all of the details, but I think at that time I was still running a Miata 4.1(?) diff, and it was way, way off for highway use.. In the end, with the VFR / 7.5 diff / and 20" tires, I settled on a 2.73 ring and pinion.. It seems most BEC guys end up around 3.0/3.1 at the diff, depending on tire size and intended use for the car..
That T5 will work as you're planning, it's just a matter of what you want/expect from it..
--ccrunner
Dean
1963 Volvo P1800 Restomod
http://locostusa.com/forums/viewtopic.php?f=36&t=163091959 Berkeley SE492 Restomod...
viewtopic.php?f=36&t=19397"ccrunner's 1960 MGA coupe Restomod" found on MGExp.com
