It is currently May 20, 2024, 10:02 am
Post new topic Reply to topic  [ 141 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10
PostPosted: March 7, 2022, 7:41 pm
Thanks.
And its a 6 speed Auto. Is that a big deal ?
American 7 5.0 T5
Lotus 15 ish?
914/H6
PostPosted: March 7, 2022, 8:56 pm
B85 wrote:
Thanks.
The 6 speed is longer, and heavier. You don't need all those gears, but I believe the 6 speed is a much better transmission than the 4 speed. The 4 speed was a pretty old design with many known failure points.
PostPosted: March 7, 2022, 9:18 pm
Would you build it again ?
How did the electric waterpump work and hold up ?
American 7 5.0 T5
Lotus 15 ish?
914/H6
PostPosted: March 8, 2022, 1:01 pm
I am building the next version of the car now. I would not go with the automatic again. It worked, but the 4L60E in stock form just didn't hold up. I believe if you talk with the guys at Mongoose Motorsports, they also went away from the 4 speed in favor of the 6 speed. I went with a manual solution years ago, and I have been very happy with that. Keep in mind, my solution means no reverse gear. For a track car, it works great.
My latest solution is a Mid Valley Engineering dog ring four speed mated directly to a Winters Quick Change IRS. It should hold 800-1000 HP, and track use, with no issue.
I think the 6 speed auto can be a great setup; depends on what you're doing with it.
PostPosted: March 8, 2022, 1:03 pm
The electric pump worked well....until it sat over the winter. Then, it corroded and failed. I was running pure, distilled water. The mfg said that would be fine. It wasn't. Run a coolant/water mixture and it should be fine.
PostPosted: March 8, 2022, 1:08 pm
Thanks,great info.
What flexplate were you using with the auto ?
American 7 5.0 T5
Lotus 15 ish?
914/H6
