It is currently Sat May 18, 2013 6:50 pm
Post new topic Reply to topic  [ 487 posts ]  Go to page Previous  1 ... 24, 25, 26, 27, 28, 29, 30 ... 33  Next
 Post subject: Re: The Roofus Special
PostPosted: Mon Mar 26, 2012 11:00 am
Flipper,
Nice idea!
If the boxing plates below the tube weren't parallel, but splayed outwards as they approached the plate it would be rather spiffy looking and perhaps even better structurally (but negligably so?). But it might be a PITA to cut those splayed filler plates to fit, rather than just tracing the edge of the bent plate to define the lower edge.
Warren
PostPosted: Mon Mar 26, 2012 12:15 pm
BBlue wrote:
No top biscuit?
Bill
There will probably be a smaller one under the frame side bracket. I might have to trim it a little to get past the x-brace.
PostPosted: Thu Apr 05, 2012 7:45 am
I hope to get a chance to work on it over the long weekend. It would be great to get the motor mounted and the car slid forward on the table so that the front suspension area could overhang the table .....maybe start installing front suspension?
PostPosted: Sun Apr 08, 2012 11:10 pm
The small tube gusset wasn't cutting it. I needed to do something more substantial, but not super heavy. I also decided the mounts needed upper biscuits.
I wanted a flange to go around the buscuit, but didn't have the right size tube...so I made my own. ...from cop car kick panels.
I started by making a strip of flat stock.
wrapped around a piece of roll bar tube
it worked!
Now that I had a better idea what I was making, I cleaned up the end
time for sheetmetal gussets
the top bolt hole was the hard part to figure out. I sleeved it and then cut the sleeve down.
I welded the circles first (welds under the big gusset)
and added speed holes
socket fits great on the top bolt
with a rubber
Now the other side.
The passenger side mount is shorter due to the engine offset (more foot room for me). I had to cram things closer to get it all to fit. hammer time!
Now to give it something to bolt to
trimmed to sit on the X-brace
test fit
did the same thing for the other side
I now have a mounted motor!
PostPosted: Sun Apr 08, 2012 11:11 pm
Now to test out my idea for using the Ford leafspring. I have no idea what sort of spring rate this car actually needs.
I bolted it to the crossmember and let the ends rest on the control arms
too high and this thing was solid as [PooPoo]! The weight of the jag and my fat ass on the crossmember didn't hardly budge it!
pull out a bunch of leaves
better
but still not much movement. you think the rust has any thing to do with that? ...duh!
I cleaned up the leaves and greased everything up (and pulled one more leaf). ...lots better!
I added some of the removed leaves to the bottom of the pack to raise the pack (lower the car)
close enough until the car gets more weight. I'm sure I will have to fine tune it some more.
PostPosted: Mon Apr 09, 2012 9:53 am
After bouncing the car on the front spring, it sure was hard to not set it on the ground and bounce it on both ends.
Before I get too carried away, I need to flip it over and weld the bottom sides of a lot of the joints.
PostPosted: Mon Apr 09, 2012 10:49 am
It is hard to resist, isn't it? I started to as I finished the front and rear suspension "again" and then thought better of it, remembering Hempy and my last go round where the rear collapsed as I had only tacked it in place!
Congrats on getting one step closer!! It'll be rolling around before you know it!
Cheers!
KS
Don't ever become a pessimist. A pessimist is correct oftener than an optimist, but an optimist has more fun, and neither can stop the march of events.-Robert A. Heinlein
Add yourself to the Locost Builders Map!
Jigsaws, Hacksaws... There is a better way! Want to get creative with metal? Want a Plasma Cutter but can't justify spending the $? Check out a DIY Plasma Cutter! A true LOCOST way!
PostPosted: Mon Apr 09, 2012 10:59 am
Please accept this pure support post :cheers:
PostPosted: Mon Apr 09, 2012 11:24 am
Somebody on another site questioned my test of the spring rate. Do y'all have any input on the subject?
If i'm not misunderstanding your proposed suspension, the control arms will have a leveraging effect on the spring, and the strength of spring will have to be greater than what your trial setup indicates.
Dave Cameron
PostPosted: Mon Apr 09, 2012 1:45 pm
Dave Cameron
That's kind of the same TFAR (that feels about right) method I used to set my initial setup. I'm sure I'll have to change it once the car is fully loaded and corner weights determined, but you have to start someplace and that's a good a method to determine that point as I could figure.
Are there better ways? Probably, but this is locost and when using such a collage of parts as we do, "proper method" isn't always a priority!
Just watch it as you get it rolling and see what it needs. 1st drive.. go easy and build up to limits. I know
I'm preaching to the choir, but some believe common sense stops at the keyboard and because they do it differently its wrong.
just be safe and use common sense and you know if you were right or need to change it.
Cheers!
KS
PostPosted: Mon Apr 09, 2012 2:02 pm
You have leaves which are dead simple to add/subtract as you have proven yourself - have a beer and stop worrying until the cars actually drivable.
PostPosted: Mon Apr 09, 2012 2:41 pm
I was just looking for input in case I was doing something that was going to alter my spring rate by 50% or something.
If I need to seriously modify my design to get the ride height I want, I'd rather know sooner than later. :?
PostPosted: Mon Apr 09, 2012 9:29 pm
Leave the extra length in the center pin bolt and u-bolts and keep the springs you've removed.
Eventually, you may decide on more rate at the same height, which means more leafs which will raise the car even if only added to the top and a thicker spacer to bring it back down.
I would not worry about maintaining a curve in the top of the frame to match the leaf arc for contact in droop. Once it is on the road and you have determined exactly how high the center of the frame should be, you might section and raise the 6 or so inch wide middle section or just fabricate a spacer from 1/8" plates and 1/2" nuts, or similar, sandwiched and welded together as a single piece.
If it sits at the desired height, but is bottoming out and/or dives really bad during hard braking, try circle track shocks with heavy damping or add a single leaf and shim it back down.
PostPosted: Sun Apr 15, 2012 11:47 am
I think when you have the spindles and wheels installed, you'll have a greater leverage effect on the spring. I'll bet you end up adding leafs back in.
Looking forward to seeing what you post from this weekend.
Mike
PostPosted: Sun Apr 15, 2012 8:21 pm
Mike
Nothing this weeknd. I stayed home. .....maybe next weekend.
Users browsing this forum: Fortysixand2, johnl and 1 guest
