Hi
Wow it's been almost a year since I last posted. My website is also a year out of date! I've got some posting to do... I've been spending my free time working on the car.
My last postings mentioned the body shell. That's now secured to the chassis. This required a lot of inner body work such as inner wheel arches and radiator fitting. The radiator is fully ducted to make use of what little air will find its way through the tiny intake in the nose. I may cut another vent under the nose to increase the breeze.
It also posted that I needed a clutch solution. The Sub EJ20G Turbo uses a hydraulic pull clutch, but the 2wd EJ18 gear box uses a cable push clutch and has smaller splines. A local clutch warehouse came up with a 2.0 n/a performance cover, and a Subaru Brat/Brumby clutch plate. I'm using the cable clutch fork and a Jamar VW hydraulic slave cyl. What a confection. I hope it can hold back the turbo's torque.
The motor is installed. 40mm Al pipes run to the front radiator. The intercooler is on the side of the engine. More shiny 50mm and 2.75" alloy pipes (you must be impressed with how us Kiwis speak metric and imperial interchangeably!). It has air feed through the car's gills - I felt nervous about air flow so I've fitted a radiator fan to it. Much of the OEM components are slightly shifted to make them fit. For exampl,e the turbo is now 50mm higher and to the right. Thus every pipe and mount has had to be tailored to fit. I fabbed the exhaust system from std bends. A work of art.
I've spent tonight rerouting vacuum hoses. My nice engine now looks like any other EPA device. Actually my cunning plan is to put a Porsche shroud on top and fix dummy down draft Dellortos on the sides. I wonder how many people this will fool.
I'm quite proud of the gear shift. It's a Toyota cable shift that runs to the very rear of the car. One cable does push-pull, while the other works a bell crank to select the gear plane. It's not a a rifle bolt action, but is positive and has a good feel.
I've scored a Nardi Classico steering wheel. Gauges are Speedhut. I can now sit in those nice red sets and go brrmm brmm.
I'll post pictures soon. I still haven't got the hang of how to do this. I've just put some stuff on my website -
http://porsche.rsk.718.googlepages.com/home. My priority is, of course , to build the car...
My next job is the fit the fuel system. I have a 30 litre alloy tank being welded up by a TIG expert.
Then the electrics. I've just bought a Rebel wiring harness which will get the basics done.
Then crank the motor. Ohhh let's hope it works.
Then interior finishing, exterior finishing, certification. Not much left to do at all!
Cheers
George50
