It is currently February 24, 2020, 12:16 am
Post new topic Reply to topic  [ 47 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: May 2, 2014, 1:01 pm
KB58 wrote:
The single huge variable that isn't being accounted for is driver skill... and daring. Put a really good driver in any Locost and it'll go faster. So what changed? Tire compound? Camber curves? Power to weight? CG location? No - nothing that defines a Locost has changed, yet it goes faster. The point is, any This vs That thread is useless other than bragging about how awesome one car is, focusing on its successes and ignoring failures. Unless it's backed up with the two cars at the same track, on the same day, with the same tires, the same engine, and driven by the same driver, it's pointless. Saying that a 400 hp-powered Locost is faster than the entry-level Caterham means what exactly? Nothing. Like Junior points out, it's easy for Locost builders to drop in a bad-ass engine, sufficient to beat any Caterham in a straight line, but that slides right back into what happens in the turns. How many turns? How long are the straightaways? What tire compounds are being used? And once again, what is the driver skill in the equation? The answer is that it's ignored when the Locost wins...
Pretty much every X vs. Y thread I've ever seen is completely pointless for coming to any sort of conclusion. If someone says that Car X is faster, then Car Y owners will simply change the rules, saying that it's only because of the money, or the driver, or the tires... and on and on.
Which is why you need a tame racing driver. I would like to see Top Gear do an episode on home built sevens. I know there are plenty in europe they could get their hands on.
Chris
"Start by doing what’s necessary; then do what’s possible; and suddenly you are doing the impossible." - St. Francis of Assisi
Building Miata Based +221 Sevenesque Roadster
PostPosted: May 4, 2014, 5:57 pm
Which why I didn't list the lap times for every goofball who ever drove around the track. Most of those were current or previous lap records in their class.
The Megabusa's times are due to a rookie driver, but the others I think are pretty representative of what a competent driver can do (but the Lotus S4 leans more toward a vintage configuration with it's Kent motor). But yes, most could lose quite a bit of time if Lewis Hamilton took them out. Hekki probably had the most talent of all the drivers (but he also had the best or second best power to weight ratio).
