It is currently January 25, 2020, 3:21 pm
Post new topic Reply to topic  [ 81 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6
PostPosted: February 18, 2019, 10:32 am
Does anyone know what software was used to generate the McSorley plans.
I'm working with a friend to design a frame that uses MGB parts.
The frame size will be based on the original Series III frame with enhancements based on a Caterham 165. When we are done with the plans, a half dozen frames will be built. Plans include making the molds for the nose and fenders.
I want to post the frame planes, for anyone interested, formatted like the McSorley plans.
Free software if at all possible :) .
A few pictures for reference,a Cat 165;
Or this
Ron
PostPosted: February 18, 2019, 1:05 pm
You could e-mail McSorley for the info on what he used, software-wise.
Depending on your skill level using complex software, and how serious you are about 3D design, I'd look at applying for a free, non-commercial license for Autodesk's Fusion 360.
More here ==> https://www.autodesk.com/products/fusion-360/free-trial
There is a significant learning cure for the product (there are a lot of on-line tutorials too), but you have absolutely everything you need available to you, plus some. When doing the molds for the body parts you will also have excellent surfacing tools whose data can be turned into practical output.
On the practical side, there are some MGB-based build logs here. I'd look through those for issues that came up, and how they were solved for those constructors. That could save you a lot of design time and/or rework at construction time.
Good luck. And don't forget to post your progress and results.
EDIT: I didn't recognize your new avatar, Ron. You've worked with SketchUp. It shouldn't be a big step up to Fusion 360.
PostPosted: February 19, 2019, 5:37 pm
Lonnie,
I will check out the builds of those who have gone before me.
Looking at the Solid Edge 2d program for the plan drawings. It's free.
I just want to put together a pdf of drawings like McSorley did. Sketchup's 3d capabilities takes care of any other needs at this point.
Ron
PostPosted: December 24, 2019, 5:31 pm
Lots of images gone. Adding this one for what it's worth.
Ron
From a series 1
PostPosted: January 20, 2020, 10:49 am
For comparison. A series 2 on the left and a Caterham 165 on the right.
The Series 2 has a Kent crossflow 1600. the weight that the orig frame was supporting can be found here
http://westfield-world.com/engineandtransmission.html
Ron
Alright then. the 165 frame is easily found by Googling Caterham 165 in the images window.
the Prince (and other) series 2 frame drawings can be had here.
viewtopic.php?f=39&t=11691
Engines heaver than the Duratec will require stouter frames.
PostPosted: January 20, 2020, 1:09 pm
Cody, Post some FEA screen shots?
