I bought a bare welded tube frame chassis with exterior rust. I stored the chassis here in humid Mississippi, and the frame now has even more rust on the exterior (as well as on the insides of the chassis tubes, visible when looking though the ends of some open chassis tube ends).
My question: I want to get rid of the rust prior to building the car, but am unsure if I should have the chassis dipped or if I should just remove the rust on the outside of the tubing with a wire wheel, etc.
I have asked others their opinions, and have gotten votes for both methods. The nearest dipping operation (100 miles away in Louisiana) said that all tubes must be sealed, which indicates to me that their rust removal dipping solution is not allowed inside the tubes, which I actually want in order to clear the rust inside of the metal tubing. Clearing the rust from inside of the tubing is the main reason I would have the frame dipped, actually.
Does anyone have any experience or recommendations on how I should proceed? BTW, I would have the chassis shipped farther away if I could get the rust problem dealt with thoroughly, and if it is important to do so.
Thanks, Jack
