It is currently July 19, 2019, 8:47 am
Post new topic Reply to topic  [ 41 posts ]  Go to page Previous  1, 2, 3
PostPosted: March 13, 2017, 12:45 am
Thanks for the info on the coolant pipes, very helpful.
PostPosted: March 17, 2017, 4:59 pm
Great to see another Ecoboost project.
I've went the same way. I have a 2.0 out of a 2015 Focus St, 6 spd trans from a 2006 Miata, I went with the Ford Perf harness and the N/S conversion. ( http://shopcapaldiracing.com/ ) had the best price on both. The N/S conversion was a good deal as it has the intake, oil pan and assorted piping.
I'm in Minnesota, so with warm weather finally showing I need to have all the boxes at work delivered to my garage at home so my wife will really question my sanity.
Gary
PostPosted: March 29, 2017, 1:59 pm
Great to hear. Have you installed the harness on the engine?
Would like to stay in touch to share our progress.
What is a NS Conversion
Thanks for the info.
PostPosted: April 4, 2017, 9:27 pm
Got it !!
Just ordered mine. I also have a 2.3 oil pan. This kit will save me from modifying the oil tube pick up.
Thanks for the tip!!!
PostPosted: July 29, 2017, 5:43 pm
Making progress. Getting engine ready, working on chassis and making minor changes.
Removed the balance shafts on the Ecoboost, install the new oil pan, oil pick up and oil plug that fed the balance shafts.
PostPosted: June 17, 2018, 3:34 pm
Well.... It has been a while.
Back to the Lotus project. Frame is almost done, made some changes to the tunnel.
Will start fabricating suspension bits, front first.
Choice of tires and wheels are 15 X 7 front and rear tires 205 X 55 x 15 front and 225 x 50 x 15 rear
plenty of tire for a light chassis, Tires will be summer compound Toyo, Dunplop etc.
Have been thinking and figuring suspension set up Droop, roll center etc..
Plenty of room (I think) for the 4 link in the rear. Figuring a simple way to change roll center in the rear.
Rear axle ratio will be 4:11 it seems to be a good match to the engine rpm torque range.
Also want the car not to be a comprise between street and track, everything in the suspension is going to be adjustable to perform in the street and at the track.
Writing the plan, then back to work on the project. This forum is very helpful and would like to thank all of you and the forum creator, it is awesome!!
Thank you
Time really flies
PostPosted: June 17, 2018, 10:51 pm
You may want to start a build log. You could actually ask the administrators to move this thread to the Build Log section and modify the name.
As to your 4-link, you may want to do Google and Google Images searches on "adjustable Satchell link." That's probably your best bet.
PostPosted: June 19, 2018, 8:56 pm
Thank you for your advice, really appreciated.
I do have a 4 link that was design for the MGB and we sell it as a kit, it works very well and simple.
I do have a question; Floorboard and firewall. My floorboard will be of steel and fire wall of aluminum. how does everyone doing the same mates the floorboard and firewall?
I will be working on the trans tunnel and floorboards next. Then suspension. I chose this process due to the ease of turning the chassis over, easier to handle.
Any advice is appreciated.
Many thanks.
PostPosted: June 20, 2018, 8:15 am
On one car I wrapped the firewall panels over the floor junction. On another I just fitted the firewall to the face of the tubes and sealed all the seams with 3M seam sealer.
PostPosted: June 20, 2018, 12:57 pm
Thank you, good advice.
Your advice trigger a couple of ideas, see what you think.
Similar to what you did on your first built.
Will extend the firewall/footwells, with a bend and bolt to the floorboards, then seal them.
Second choice, make the firewall of 24/ gauge steel and weld to the floor. I don't think that it will add that much weight.
The chassis stiffness may be increase.
PostPosted: October 13, 2018, 4:39 pm
I have done some research on glues, epoxy, resin etc...
I have decided to glue the floor board panel to the chassis. Floor board will not carry any load, braces for the seats. Same with the firewall and cockpit panels. Gluing will carry the load evenly.
Then it will have to be seal with sealer.
Has anyone in this forum gone through the process of gluing the panels?
