The 1" and 3/4" square tube is generally 16 gauge.
I agree with buying a decent MIG welder, up front. I ended up getting a Miller 190, after suffering for years with a cheap MIG. Cheap welders break down, just when you need them not to, and since they're pretty much made "offshore", getting replacement parts can be a real pain. Get a Miller, Hobart, etc., and parts are readily available, and chances are, with a good machine, you won't need any for the duration of your build.
Also, your welds will likely be better with a good machine, as they tend to be very consistent - this results in a LOT less "iffy weld, cut it out, & weld it again" cycles.
Finally, assuming you ever actually decide you're not going to do any more welding (yeah, like THAT will happen!
) the resale value of a quality, name-brand machine will be MUCH higher...so your overall cost for having & using it will be cheaper than the "El-Cheapo" machine from the start.
I did a LOT of research before buying my new Miller 190 machine. It has "AutoSet" (simply dial the thickness of the metal you're welding, and it does the rest of the settings for you), there's all sorts of accessories available (I recently bought a Miller Spool Mate 100 spool gun to go with it, so I can weld aluminum, for example). I just did a quick check online, and it looks like they can be had new for about $900 USD. Of course, you'd still need a bottle of welding gas, but that cost is the same, regardless of whether you buy a cheap offshore welder or a name brand one. Miller also has incentive programs on all the time - I got $200USD off the price of my welder, from Miller, via a rebate check. I suspect that once they've got you into their machines, you'll stick with them.
I've talked to a lot of welders over the years, and none of them recommend a cheap machine. They've all tried them at one time or another, and ended up with quality machines instead (mostly Miller, as it happens - one of the things that helped me decide on which brand to buy).
