It is currently July 19, 2019, 12:27 pm
PostPosted: August 13, 2018, 1:08 pm
Thinking out loud if anyone would like to partake.
So I found some inspiration for a different type of chassis design. Ideally I'd like to throw an LS3 in a tube frame chassis of my own design for street/track fun. I have posted earlier of a strictly load path driven chassis design (image at bottom) but it just seems like it will be too ugly going down the street. I don't really want to bother with making a body.
Then I came across these rock bouncers (google them if you haven't seen how ridiculous the are). Obviously they are designed for offroad, 4wd, solid axles, etc. But I was thinking I could take some of their design cues: shock mount hoops, similarly angled A pillar and B pillar, etc, and include them into a chassis design. Then I could add aluminum panels between many of the rails to create a body-like structure and keep some of the wind out of the car (the middle photo includes some of these type panels). The car would have double A-arm suspension front and rear.
Any thoughts? Immediate concerns would be added weight from some non-ideal load paths, limited sight lines with the shock hoops, and ingress/egress.
Rock bouncers for inspiration:
Boring engineering driven chassis design I did a few years back:
Thanks.
PostPosted: August 13, 2018, 3:03 pm
If you want it to be a performer on the track, you might want to start with the suspension first. The chassis layout will flow in large part from those considerations plus the packaging for the driver, passenger(s), engine, transmission, rear axle and other large items like the fuel tank.
The problem with big engines is getting the power they produce effectively onto the ground in a controllable way.
PostPosted: August 13, 2018, 4:35 pm
I agree. I've designed a few suspension setups. The initial chassis design I included at the bottom was designed around control arm pickup points. This post was more to feel out the chassis arrangement.
PostPosted: August 14, 2018, 5:39 am
Thanks.
There is always something to learn from different envelops,
with rock crawlers however you are looking at a rather remote set of engineering factors that do not fit into a seven design. Rock crawlers are not designed for speed and overbuilt for punishment, suspensions have long legs to hug the terrain...etc. However you have a valid question, the tube structure of integrated roofs is worth looking at :)
PostPosted: August 14, 2018, 9:08 am
And here I thought that proper suspension design started with the tires and wheels chosen.
PostPosted: August 14, 2018, 11:46 am
You have a point, but honestly in a world where we aren't fabbing our own wheel assemblies, I think it really revolves around the uprights we utilize.
PostPosted: August 14, 2018, 12:09 pm
@SkiRideDrive
Reinforcing your point, tires used to come in a limited number of sizes in terms of diameter, aspect ratio, rubber compounds, etc., etc. With today's huge variety of vehicle types and large number of tire and wheel manufacturer's, your choices in all those dimensions are enormous.
You can use a resource like Tirerack.com to go from your desired tire specifications (rolling diameter, aspect ratio, general compound type, tread type, etc.) to a particular tire vendor and tire model/size. Also, as I did with my build, wheel makers have a huge variety of wheel sizes available. I ordered my two rear wheels with different characteristics of offset and rim width to accommodate the particular tires I selected for front and rear, and so that my rear track was smaller than the donor setup. The wheel side that shows to the world looks identical on all 4. Extra cost? Zero$$$. They manufacture on demand.
PostPosted: August 23, 2018, 11:56 am
As a middle ground between the rock bouncers and the pure triangulated design, check out the Ultra4 race cars. There are more engineering driven, but some of them have a decent aesthetic appeal to them. https://bomberfab.com/ is one of the more popular Ultra4 chassis, the other is https://goatbuilt.com/
Simple changes to your current chassis design can make a big aesthetic difference. For your door bars, instead of doing a the X like you have it, you can do a single tube for the top V and another single tube for the bottom V, then use a formed sheetmetal filler with dimple dies to create a gusset. Similar to what is below. This will help add the soft radius that lends to the "flowy" chassy design.
PostPosted: December 7, 2018, 12:40 am
Somehow I ran across "rock bouncers" on Youtube one night, very cool and cool looking.
But for a street car how about something similar for the Ar-i-el At-om? Minimal body and lots of exposed frame with some style.
