It is currently January 26, 2021, 3:21 pm
Post new topic Reply to topic  [ 422 posts ]  Go to page Previous  1 ... 25, 26, 27, 28, 29  Next
PostPosted: July 13, 2016, 10:33 am
Bobber wrote:
Still planning on the Big Block? What plans are you working from?
Not following here...
also i sent the main and middle tube drawings.
PostPosted: July 13, 2016, 1:00 pm
Whoops, forgot which car I was working on. But while I'm at it, can I size your chassis for a blown big block Chev? I just happen to have something for you in back.
PostPosted: July 13, 2016, 1:06 pm
still not following...
PostPosted: July 14, 2016, 11:24 am
I haven’t added all the tubes yet, but I wanted to see how much strength this structure gets out of the side rails alone. The side rails don’t do much, less than 1000 ft lb per degree. The problem is that the front and rear "boxes" do not tie the rails together well.
The side rails and roll bar are 2”x0.065” wall tubing. Everything else is 1”x0.065”. Chassis bare weight is at 125 lb.
PostPosted: July 14, 2016, 11:49 am
that looks way off from my cad model which says 205lbs. the main suspension boxes are also 2.0 x.065. There are also a few x braces missing in the rear suspension box.
i sent you an email with the tube sizes.
PostPosted: July 14, 2016, 1:52 pm
I threw in some more steel to stiffen it up but I still can’t even get up to 1000 ft lb per degree. Bare chassis weight is 145 lb. Is there an analysis by someone else that may indicate why I’m not getting much strength out of this chassis?
PostPosted: July 14, 2016, 2:14 pm
that still looks off. the rear suspension box should be 2" tube. Not sure why it is like that. here is the only other simulation that i have.
PostPosted: July 14, 2016, 3:00 pm
Yes, right now I am experimenting with the tubes to see who contributes to the stiffness. I've been analyzing the chassis for pure torsion. Is that what your program is optimizing for? Have you analyzed your side rail framework independent of the end "boxes". I may try that.
Were the end boxes designed for Team 321 suspension?
PostPosted: July 14, 2016, 3:08 pm
that was all done for me a long time ago. i think it was optimizing for torsion. My suspension boxes were designed to fit my engine and my own custom suspension. I kind of think this thread was hijacked for its original intent of the lotus chassis. Should we start a new one?
Something has to be way off. It was mentioned before that the At-om chassis has around 4k lbs torsional rigidity so mine should be at least that or better... agree?
PostPosted: July 14, 2016, 4:00 pm
I agree it might be a good idea to isolate this piece of thread. I'm seeing something I don't understand in the At-om structure and I have to chase that down. Where did the 4000 ft lb number come from?
PostPosted: March 14, 2018, 2:58 pm
Im a long time AutoCad user. Downloaded AutoCad Fusion 360 for free a while back to try my luck at CAM failed. Currently trying, and failing, again at load simulations. Got as far as to import my dxf stick fram and assign material but cant for the life of me figure out loads and constraints.
link to STEP file
https://drive.google.com/open?id=1D0v6i ... VLAqfsme2B
PostPosted: March 16, 2018, 11:47 am
getting warmer. But i keep getting Mesh Errors as i try to add more material
https://youtu.be/9sI0-QUnWV0
PostPosted: May 21, 2018, 11:46 am
Is there any way you can generate finer mesh for specific areas?
That's how I had to fix a couple problem areas in my model when doing FEA, for some reason my upper outside tubes for the engine bay always gave me issues even though they are designed the same way as everything else. I made it so those two tubes were a finer curve based mesh and everything else is a more simple triangle based and POOF no issues.
Keep in mind this is in Solidworks... I don't know if fusion360 has this capability.
My build -> viewtopic.php?t=15585
PostPosted: July 24, 2018, 12:49 pm
BUMP!
PostPosted: September 18, 2020, 5:56 am
Hey, 2020 calling. Anyone done anything since 2018?
What toolchain are you using for static stress analysis?
