It is currently May 3, 2024, 6:03 pm
Post new topic Reply to topic  [ 233 posts ]  Go to page Previous  1 ... 12, 13, 14, 15, 16
PostPosted: March 20, 2024, 1:14 am
Has anyone had luck adapting an oem s2000 header, pr other oem header to you Duratec? With my 442 chassis I am not sure any other header might be adapted short of going full custom
PostPosted: March 20, 2024, 4:42 pm
The obvious choices would be Caterham ($$$$!!!), a header for a focus or escape as it will be pointing the right direction and the primaries could be extended through the side of the bonnet, or use the ford manifold that is clean and much like a shorty header. Just clean and ceramic coat, then add a mandrel elbow at the head pipe to bring the exhaust outboard of the frame. New manifolds around under $100. It will also help keep the heat down under the bonnet compared to a thin walled header with the same finish.
A long tube header with the same bore spacing could be used with a new flange to fit the duratec and the primaries would need to be extended anyway. A long tube header for the older lima 2.3l might work.
PostPosted: March 20, 2024, 10:03 pm
I guess that depends how I want to approach the exhaust in general, I could certainly go that route, But this is part of the car where I expect to spend some money to have a header and exhaust I like. Or whatever I have energy for when it comes up on the to do list
PostPosted: March 20, 2024, 10:16 pm
Designing and building your own header can be a very rewarding side project, one that you will be proud of every time you look at it.
PostPosted: March 20, 2024, 10:37 pm
I was looking at 1.5" ID 304 stainless bends and sections. I saw some on AliExpress that had an attractive price, but listed 1.5" OD so I need to figure that out before thinking about that route. I have a Manifold plate already and have been getting an Idea of what is involved, and I may as well 3d print some mock up tubes or bends to plan it out. I am open to any suggestions on where to get stainless sections or J bends.
They have 38mm and 45mm OD tubing with a 1.5" wall. that would mean a small stepdown in size of 2.5mm if using the 38mm tubing, or a step up of about 5mm in diameter over my port size. Obviously so close to the port you want a smooth transition into the primarys. Might have to pay for pipes sized for ID
PostPosted: March 21, 2024, 10:45 am
Tubing is always measured on the OD. Pipe is always measured on the ID. Tubing slightly too small for the port is fine, as it can be tacked in place and, using a brass drift, stretched slightly to reach out the the flange walls. Oh, and anything from AliExpress will most likely be metric, regardless of size claims.
PostPosted: May 2, 2024, 11:09 am
Doing a little fuel pump shopping. I have the JAZ sumped 8 gallon tank. I think I am looking for a 60gph external pump running 60 psi. This is for a naturally aspirated 2.5.
Stock fuel rail pressure is like 55psi but I am not sure if you cna go with a significantly higher pressure pump without causing additional concerns
How does a duratec generally control it's fuel pressure? I am going to run a microsquirt.
PostPosted: May 2, 2024, 5:36 pm
Variable output pump. Better to use an older, traditional return line system and vacuum/boost ref fpr with the ms.
