It is currently August 3, 2020, 7:05 pm
Post new topic Reply to topic  [ 104 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 7  Next
PostPosted: February 13, 2013, 8:31 pm
When looking for a donor Ranger, does it matter if the truck is an auto or manual?
I'm thinking about using a Miata 5 speed anyway.
PostPosted: February 14, 2013, 8:32 am
John, my engine is a Ranger. From a practical standpoint, I've decided that while oil pan clearance is important, for normal installations there is not much to be gained in making it a lot more than bellhousing clearance.
My engine was for an automatic. The only problem was length of flywheel bolts. They were a couple of mm short for the stock manual flywheel, nothing that a $50 set of bolts (OUCH!) did not cure. If your going to use the OEM automatic 'puter, you might run into issues.
Marcus, engine weighed 235 pounds with motor mounts, stock flywheel and clutch. My weights have to be correct, they were made with the same brand of bathroom scale as the one in the photo! Fortunately, the weights are very compatible.
Bill
PostPosted: February 19, 2013, 5:59 pm
john hennessy wrote:
Andrew, how deep is the pan with the hole in it?
From the flange where it mates to the block to the lowest part of the pan it is about 4 7/8". Mine is actually a little lower thanks to the "modification" but you get the point.
PostPosted: February 19, 2013, 9:05 pm
andrew,
which side of the engine is the dip stick, mine is on the exhaust side
PostPosted: February 19, 2013, 10:18 pm
This one is on the intake side.
PostPosted: November 19, 2013, 8:39 am
The 2.5 has the dipstick going through the head, between #1 @ 2 on the intake side.
Bill
PostPosted: November 20, 2013, 2:05 am
Bill
Interesting. Any chance you would be able to get some pics and detail any other differences you've found so far? Like is the height of the block itself the same as the D23? Is the head and/or valve cover taller? I believe at least the intake ports (and maybe exhaust ports too?) are supposed to be a fair bit bigger than on the previous Duratec's, but I'm curious to what degree?
PostPosted: November 20, 2013, 10:49 am
Justin, this is what I can determine.
The valve cover on the 2.5 is about 1/4" taller than the aluminum valve 2.3 cover. The overall height of the 2.5 is 26.5" to the top of the "710". Can't really measure the 2.3 overall. The oil pan on the 2.3 extends 1/2" lower than the 2.5.
The front pulley on the 2.5 extends 2 1/4" from the timing chain cover. The 2.3 is 1 3/4", too the head of the crank bolt.
The crank pulley on the 2.5 is 6" diameter. 2.3 is 5 1/4"
Water pump pulley on the 2.5 is 4 1/2" diameter. 2.3 is 4 1/8"
Intake port height is 1.550 vs. 1.450. Width is the same.
Exhaust ports are identical
For anyone interested in using the stock exhaust manifold, the 2.5 has 1.560" diameter primaries, slightly larger than the ports. 2.3's are 1.375". Both are very nice castings. The stock intake runner length is 10 1/2" for the 2.5, 16" for the 2.3. The 2.5 runners are obviously larger in diameter, but actual measurements are beyond my capability.
The 2.5 throttle is drive by wire. As near as I can determine, the injectors have the same flow ratings. I think that is very interesting. Here are the respective part numbers:
2.5 - 280 158 162
2.3 - 280 156 155
Here is a top photo
Bill
PostPosted: November 20, 2013, 10:58 am
BBlue wrote:
2.5 - 280 158 162
Is it definitely 158?
Only reason I ask is my 2007 2.0 came with 0-280-156-162 injectors and I had a heck of a time reading if it was a "6" or an "8" when I was researching the specs.
Somewhat unrelated but I found these two sites useful when I was setting up the MS to use the stock injectors:
http://users.erols.com/srweiss/tableifc.htm
http://www.fuelinjector.citymaker.com/F ... Rates.html
PostPosted: November 20, 2013, 1:30 pm
a.moore wrote:
BBlue wrote:
2.5 - 280 158 162
Yep. No doubt about, used a magnifying glass. Very clear under magnification.
Bill
PostPosted: February 25, 2014, 12:16 am
I'm trying to find the 2.5 redline. Ford says max hp is at 6000, lets it rev to 6500. Is there anymore left?
Bill
PostPosted: April 7, 2014, 11:44 pm
Can anyone confirm whether there are any solid OEM flywheels for the Miata / Mazda/ Focus and which ones might interchange?
I dont want a dual mass anchor and I am looking to avoid paying for a Fidenza..
I know that the UK Fiesta ST (Duratec 2.0 / IB5+ gearbox), uses a solid flywheel for example.
bu there also seem to be several different starter motors # of teeth , different diameters etc.
thanks
PostPosted: April 8, 2014, 12:08 pm
I believe that the native RWD (06+ Miata and 01.5+ Ranger) use a solid flywheel. The Miata being the lighter of the two. My understanding is that most of the FWD applications use a 'dumass' flywheel stock. Not only are the ring gears different between variants, so too are the setup heights and offsets. So a stock 06+ Miata flywheel will not interchange with a stock 01.5+ Ranger flywheel, and neither of which will interchange with a stock 03-07 2.3L/05-11 2.0L Focus flywheel. Thus your flywheel options will be more-or-less predetermined by your transmission selection.
PostPosted: April 8, 2014, 12:24 pm
Many thanks Justin,
Starter motor goes with bellhousing, so flywheel is determined by tranny.
Not good for a middy then; looks like I will have to shell out for an aftermarket jobbie.
None of the Mazda range use a solid I suppose?
PostPosted: April 8, 2014, 2:51 pm
I don't know for sure, but the Mazda's also use a different transmission than the Focus. So chances are high that they too use a different (non-interchangeable) flywheel. Exedy offers a complete clutch/flywheel kit including solid flywheel for Fidanza flywheel money.
